Hello,
All out of the sudden the inverter on my CNC stopped working,
Please see the error in the attached picture.
Can someone please give a hint on what to do next? or what does the error code mean?
I have measured the input power on the device
- Build Thread- CNC 6040 6040Z - China Made CNC Routers
- Australia Upgrading the latest 6040 from China
- CNC 6040 Spindle Won't Stop
- Need Help!- CNC 6040 VFD spindle control
Mactec54
So pin 4 has no continuity to the spindle body. It never had continuity.When the machine came it wasnt grounded. i had to get shielded cables and ground the the spindle.
i measured the resistance on the windings i see about 6 ohms between any 2 of the pins from 1 to 3 and no continuity from the winding pins to pin 4.
I think that the spindle is still good. the problem should be in the inverter after my judgement.
the input power of the inverter is 230V.
I have no ideea what to do next..
the inverter is "JD inverter" i found no info online on it. The ebay seller doesn't respond.
So you do have a Ground wire from Pin 4 to the VFD Ground, and the spindle is grounded to Pin 4, make sure of this, Your main Power supply Ground also has to got to the VFD Ground Terminal
Take some photos of what you have, the VFD may be Damaged, there are a few things to check first though
Mactec54
Hello
I also made the same mistake.
Are you solving this problem?
