Thanks DMcKee for this thread. I have the same machine and have been able to connect limit switches to those pins I also found the oval shaped solder pads at the top right of the board above the circle you marked around the spot for the 25 pin header can be used for a z probe connection as it connects via a resistor and opto coupler to pin 15 on the parallel port.
