Greeting guys and Gals
I have recently purchased and received an xj6090 from XYZ TECH, here in china and ARRRRRRRRRGGGGGGG
background info; I am an expat American teaching English her in china fun right depends on the day
so I recently received the XJ6090 from XYZ TECH. and it is a beautiful machine and surprisingly quiet, but that said then the machine comes with no manuals save an half baked installation guide of the software, but nothing for the inverter or how to use the machine nothing Natta zip zilch zero info
the basics
machine xj6090 dedicated windows xp computer
software used AutoCAD 2010 to draw Artcam Pro to nest and generate the Gcode , and ncstudios 5.5.60 to operate the machine
the problem comes when I run the simulation I get a -48 delta motion out of limit alert what is delta motion ?
but the simulation completes and says successfully completed and give a time to finish, so when I try to actually cut the parts , well another story
I have home zeroed the machine and work origin zeroed the machine to the top of the 4mm panel to be cut, so, when I hit run the spindle spools up and the machine starts to move up z 10mm for the safety clearance and then to the first cut , but then moves up the z axis another 10mm +- and then starts to cut all axis normally but in the air 20 or so mm above the zeros set it will go thru the whole process moving up and down the z as normal and all the others but never a parts cut unless I am making airships which I am not
the So called tech and I spent the entire day Friday online in broken text English trying to figure this out no avail he finally sent me a sample *.nc file to try and it worked perfectly in all axis, he is using artcut 7 I am using artcam pro and his Gcode is totally different than mine but we are both saving as *.nc files and now I am trying to find an English version of artcut 7 which is like trying to find a manatee in the gulf of Mexico during a hurricane. yea I am from Florida!
attached first is my Gcode second is his Gcode both for ncstudios 3-4 machine 5-6 models I manually cut the parts out for these ships as prototypes before buying the machine lots of time to do just on took a week of cutting manually
help mayday kick ,scratch , scream , holler, temper tantrum, any and all assistance would be of great help
by the way trying to get help here ha ha ha ha , not happening the people here other cnc guys think I am trying to take there customers so wont help or tell me anything to get me to go away , I just want to make ship parts not take there sign making business hell I don't even speak Chinese, and my Chinese wife does not speak cnc English so the help is not forth coming
John Anderson
Fleetside Models
