I suggest that you ask this question, along with a current report from your controller, on the Centroid Acorn support forum
Hello,
Iam trying to use the outputs of my Ether1616 board with Acorn and can not get any of them to work. Using the wizard i tried assigning an "OUTPUT1" to output 33 and did an mdi of M61 and also M94/61 but the led and relay does nothing. Also tried assigning a Custom Output of M94M95111 to the Ether1616 output 33 and did an mdi of M94/111 and nothing happens.
Only time i can get an Ether1616 output to work is when using the <CTRL>, <ALT> and <f> button press on the Diagnostics Screen.
Has anyone had this issue or know what iam doing wrong?
Thanks,
Troy
www.tsjobshop.com, www.homecncstuff.elementfx.com
Gary Campbell GCnC Control
Servo Control & ATC Retrofits
