The first thing to try is cleaning the card edge fingers and motherboard slot and re-plugging several times time make sure the connection is good.
The board is fairly complex, so anything beyond that is not DIY friendly.
The chance of the actual IC being bad is near zero. The problem is most likely some bad connection to the IC or supporting components preventing it from running.
