PWM Pulse Width Modular for Laser
Results 1 to 5 of 5
Thread: PWM Pulse Width Modular for Laser
    Aug 2005
    Default PWM Pulse Width Modular for Laser
    Does Centroid controller had a PWM output for running a laser?
    Rob
    Feb 2008
    Default Re: PWM Pulse Width Modular for Laser
    No.
    There is a 0-10V analog voltage output, normally used for spindle speed control, which can be used for other purposes on a machine with no spindle.
    If your laser requires PWM, then you could probably assemble some type of interface circuit (maybe using an Arduino type board?) that will read the analog voltage and output a PWM sequence.
    Feb 2008
    Aug 2005
    Quote Originally Posted by cncsnw View Post
    No.
    That’s encouraging. The PWM on Centroid forum might be the trick.
    I surprised Centroid hasn’t come up with this.
    Rob
    Member Ntl's Avatar
    Aug 2018
    Quote Originally Posted by artracing View Post
    Rob
    If you are talking about the Acorn it has a 0-10v analog on the board.
