Motion error 411 axis full power without motion
Results 1 to 2 of 2
Thread: Motion error 411 axis full power without motion
    Sep 2019
    Default Motion error 411 axis full power without motion
    Hello Forum,
    I'm the new guy, I have a Vectrax mill with centroid controls MSC M-15 CPU7
    today I powered up and I got the 411 error
    I got 120VDC on terminal 9 and 10
    I checked all the fuses and they are okay.
    All the red LED's for the axis go out when I try to jog each axis.
    only the fault lED is lit
    any ideas?
    your help is appreciated.
    Feb 2008
    Default Re: Motion error 411 axis full power without motion
    If the green UV and USV LEDs are out, even though you have 120VDC going into the VM+ and VM- ("GND") terminals, then there is a problem on the drive board. Possibly a blown fuse on the drive board, but if that is the case, there is most likely a more serious problem behind it.
    If in fact the UV and USV LEDs are lit, then the problem is more likely to be with the limit switch circuit (the 8-position plug mid-way along the front edge of the drive board).
