"I'm beginning to feel a bit dumb. I can not get the Leadshine HBS86H hybrid step motor controller
to work with the hybrid stepper motor. The motor is a Model 86HSE.5N-B32 model.
First are these compatible?"
Does the Leadshine manual or website list that drive as compatible for that motor, or visa versa?
"I am using an Acorn control board to control the step motor controller."
Which Acorn schematic are you using?
"I can make the motor on bench test jog CW and CCW but as soon as I stop jogging
the motor the jerks about 1 turn and the Leadshine controller board goes into a following
error (7 blips on the alarm LED). Only way to clear error is to unplug the controller."
What does the manual say is the error for 7 pulses?
"I have tried all kinds of different encoder wire hookups to no avail.
Tried E mailing Leadshine with only a non deliverable response."
There is only one way to wire the motor and encoder. It is clearly shown in the Leadshine drive manual
