centroid acorn and CNC 12 lathe pro review
Results 1 to 18 of 18
Thread: centroid acorn and CNC 12 lathe pro review
    Mar 2018
    Default centroid acorn and CNC 12 lathe pro review
    I wanted to post a quick review of my experiences with centroid acorn. I purchased centroid for my first mini lathe cnc conversion.
    Some background: I am fairly new to CNC. I have built 4 CNC machines from scratch in a distinctly hobby grade process rife with mistakes. The first 3 machines used GRBL though I have dabbled with G2Core. My first lathe was a 8x16 import that had a ridiculous quantity of problems. Fixing it up taught me quite a lot about the machine and it's limitations but i am in no way a professional machinist. One big issue I had with this lathe was that the change gears did not match the manual and the banjo did not actually work for many of the thread pitches. This prevented me from any practical threading. I did quite a lot of research and initially settled on trying to make an electronic lead screw. I made some progress with the design by reading through the Russian ELS project forums and I had a semi working prototype. Unfortunately I had to move and I was unable to continue to have the space to work on the 8x16 lathe. Some months later I found a deal on a 7x10 lathe which was small enough for me to use in my new place. I decided to buy an acorn so I could spend less time tinkering and more time making. The acorn is marketed as hobby friendly and I am in no way building a manufacturing capability. My goals were to learn basics about CNC lathe, do threading, and to save the time figuring out how the spindle sync ports of GRBL worked.
    I purchased the acorn on amazon which made for quick shipping. The packaging was decent and I think the hardware package is well thought out. You get the main board, a relay breakout, a quality 24v/5v power supply, and a quality ethernet cable. The power supply has no cover and I think they should include a cover with a switch for safety but this is in no way a big issue for anyone familiar with the safety risks of live mains exposed terminals. The main board is geared towards industrial grade components using 24v. There is also a DB25 connection to provide connections to "hobby" grade components. The DB25 breakout connections are not isolated. If you wanted isolated 5v connections you'd need to supply and wire your own breakout. I ordered a cable and breakout connector from Amazon and was able to connect my limit switches and stepper motors without much trouble. I would advise you to look at the breakout and ensure it can be screwed to the board. Some breakouts do not include the screw posts. The DB25 configuration path does not provide PWM outputs (i think this is planned) and using a stepper enable signal is not supported which is a bit disappointing. The board includes a multitude of status LEDs which are very nice for giving a visual indication of the status of the signal pins like your end stops or probe. The board also includes a 0-10v analog out for controlling spindle speed. The brains of the board is a seed studio beagle board which can be replaced. it is not really clear what the board is running though I'd expect it is some flavor of linux. All communication with the board is via ethernet. I have not found any indication of how the board is supposed to react to a power off. Generally linux doesn't like to be turned off without running a shutdown sequence to sync the "disks". The documentation seems to just say to "power cycle" the board. It is unclear how safe this is for the device and I would be interested to know how data corruption is avoided. The board is replaceable but they cost around $70 and if you do not get an RMA you need to pay a fee to get the license setup on a new board. The breakout board includes a DB9 connection for an encoder. I made a bad assumption about the encoder specs and assumed a standard quadrature interface would work. A differential quadrature signal is required with a Z pulse (once per rotation) and they recommend 2000CPR minimum.
    My experience with the hardware was overall good. I wish I had done a bit more research when ordering so that I could have had all of the components needed at the same time. For hobby grade components you should order a db25 breakout, a db9 breakout (if you plan to use an encoder) and cables for both. The documentation for hobby grade connectivity isn't expansive. For someone who's done a few builds the schematics are clear and it shouldn't be hard to get up and running. For someone doing their first build who does not have much experience reading schematics I think they may have a bit of a struggle.
    The software that comes free with the board is fairly feature limited. They supply good charts that show what features are supported under the various software options. For a lathe with spindle sync you must purchase the CNC 12 Lathe pro license. The lathe pro license doesn't change the software much at all other than when running commands. The free version will let you create g-code for threading it just will not run.
    Security: The software installation guide goes through great lengths to have users disable security. This includes elevating user privileges to administrator, turning off user account control, disabling the firewall, and disabling antivirus. I suppose this could be fine if they made a very strong recommendation for network isolation. If the machine isn't connected to the internet then your risks with following the installation instructions would be limited however they do not discuss the implications of removing security controls and they do not recommend any mitigation like network isolation. They also do not warn to ensure the machine isn't connected to the internet at some later date which I'm sure will happen to some users. In my case I was planning on using my laptop to control the acorn and I did not want to have to have a 2nd laptop there so I could read the documentation or browse the forums troubleshooting issues so I needed to have internet connectivity. I was able to figure out how to connect to the acorn without turning off all my security but this is likely beyond the ability of the typical user. I'm sure that the multitude of configuration issues created by 3rd party firewalls and antivirus creates a monumental quantity of support issues but I also have not seen much software recently that went the "disable everything" route which honestly seems irresponsible in this day and age. For a non-hobby machine likely to be isolated and dedicated this all makes more sense but I can't say their security posture is friendly to the hobby user.
    User Interface: This is where I started to have major problems. The user interface seems to be very focused on a dedicated PC with a touch screen. It feels like DOS or windows 3.1 in 1995. The window management features and best practices of the OS are ignored. There seems to be multiple programs running that must use some IPC to coordinate. The main information screen takes up about 2/3 of the left portion of the screen. The right 1/3 is consumed by a 2nd window for the virtual control panel (VCP) . This panel allows things like spindle control jogging etc. Because there are 3 programs running and none of them seem to use the OS's window management I have had issues with focus/z order and overlays obscuring the main window's display. There is no title bar. There are no minimize/maximize/close buttons. You can't effectively use Alt+Tab to switch programs. If you Alt+Tab the VCP window stays on top and obscures 1/3 of your screen. The icons all look kinda the same so you have to hunt to minimize it. For an expert user this may not be a problem but when you are trying to use a browser to read the documentation or figure something out this quickly becomes a major PITA. if you have a 2nd laptop or computer and don't plan on ever having to read another window this likely isn't a problem.
    On the positive side I found the jog controls a breath of fresh air compared to Grbl. Grbl didn't have room for a real jogging implementation which is self admitted by the developers. This makes Grbl pretty easy to crash while jogging. Keyboard jogging with the Acorn worked well and there seems to be good options to use alternative controllers to the touch screen.
    The next issue I had was that you have to be connected to use the software. This means that you must stand at your lathe to use the CAM software features or you must trust the device and connect it to your home's network. Based on the security advice they provide for software setup it is hard to trust the device. I would also need to connect it via wifi since I do not have a close Ethernet jack wired which would require another device to purchase. If you want to fully network your acorn this is not an issue. I honestly can't understand why they require the board to be connected to run the software maybe someone else knows.
    Documentation: I'm going to try my best to be fair here but this is the biggest issue I've had. There is a lot to be documented and for the most part they do a good job but some of the documentation seems to be made to be paired with training. This makes sense when you think about how they have evolved their business model. Unfortunately this leaves the hobby user to infer quite a lot. My first hurdle was with the procedure to use the auto tool setting features. I dug into the manual and found the bulk of the documentation was focused on the manual process. The automated process documentation was extremely basic and some fundamental elements of the system were not explained. I watched multiple videos on youtube but I was not confident I had a solid grasp of the concepts. I tried to post a thread on their forum to clear up the questions I had. I tried to make it clear that I didn't understand the documentation but the response I got was that "you have a basic misunderstanding of Tool Offset values" I was told to read the documentation and to watch the video. I did both again and tried to contribute to clarifying the documentation and to point out the video covering the manual process didn't translate directly to the automated process. I was told to follow the steps in the video again. I reiterated that I had tried to do that and that it was not clear what the best practices for the automated feature were. I even posted a video documenting my struggles. I eventually got a response specific to auto tool setting but it was more of a hybrid between manual and auto features which left me with more questions that went unanswered. I probed for a follow up and was told to start a new thread or add to someone else's. I believe the responded assumed I had open questions in another thread and didn't bother to read the thread I posted in. I'm guess he was just trying to help in between doing other things but I was feeling exasperated at this point and considering just giving up on getting my documentation questions answered.
    I had similar frustration with the CAM documentation but I didn't invest the effort in getting help from the forums. Simularly the CAM documentation seems designed to be paired with training classes. I was able to quickly use the diameter turning and threading features but using the arc and taper functions was much less intuitive so I started looking for alternatives. I've been using Fusion 360 for a while made my first attempt to create some g-code for the Acorn. The problem is that the post processor included with fusion 360 only does milling CAM. Trying to run it for a lathe setup produces an error. I found a lathe CAM post processor by Franco on youtube but it has to be manually installed and downloaded from dropbox. This may be beyond the average hobby user's ability to find and install. If you are forced to use the CNC 12 CAM there is no simulation, no crash detection, and the documentation is fairly limited in my opinion.
    Pros: The hardware package is good, the system is highly configurable. It supports spindle sync with little setup effort. Hobby grade stepper drivers, limit switches, and touch probes are fairly easy to configure. Threading was intuitive and easy to get started with.
    Cons: Documentation seems to assume pairing with training, some features are not documented, and community support for lathe work seems very limited. The support forums have 2 main folks who seem to reply to most lathe oriented threads and the focus seems to be more on reducing support effort vs great customer experiences. The tone in most of the threads I read was "this is the way it is". I found this tone frustrating. I would prefer to understand why something is done the way it is so that I can have a more fundamental understanding that has a better chance of building on when I run into issues later. I did not get the impression criticism is welcome or that they wanted "hobby" customer feedback on how to improve the product. The software UI is extremely dated and annoying to use when trying to also read documentation or look up a thread table. A 2nd screen may make the software UI issue moot but may not fit in your workspace. There is no part position probing routines though you can use the g-codes like M115/116 directly. You can also write your own macros but it is surprising there isn't a library of community supported macros easily available for Lathe pro. If you buy the $400 digitizing package you can probe part positions via canned routines.
    Centroid acorn overall: While the hardware setup was fairly easy the learning curve on the software was steep. I can't say I had a good experience with the support forums. The CNC lathe alternatives which allow for threading are slim pickings. There are 2 or 3 ports of Grbl that attempt spindle sync. LinuxCNC/Machinekit seem to have mature code but the learning curve seems very steep. The Electronic lead screw alternatives seem to offer a much lower learning curve but at a similar overall cost. I think there is an opportunity for Centroid to embrace the community for improvements to the product but the market may not support such and investment. It may make sense to remove the CAM functionality into a separate package and include spindle sync with the hardware. Having auto tool setting but no auto part probing routines doesn't make sense.
    Hope this helps someone. This was my experience and I'm sure the experience varies quite a lot between users of various backgrounds and skill levels.
    PS: Quick note on my mini lathe build overall: I see these builds as learning experiences. I suppose the main lesson I learned is that lathe CNC is pretty difficult overall and that you can do a hell of a lot with a manual lathe or running it in a semi automatic way. The best thing about the lathe CNC setup is the lack of change gears and automated threading. Threading can also be done with an electronic lead screw. The effort between setting up an ELS and the full CNC is fairly small. The effort to learn how to use the CNC platform (including CAM) is larger than I expected and you should expect a fairly steep learning curve. The full CNC build will put a spotlight on your machine's mechanical flaws. I'm not sure you can cut complex toolpaths with the backlash in the cross slide lead screw or with open loop steppers. A ball screw is ideal but fitting a ball screw to a 7x10 mini lathe isn't exactly easy. The mini lathe was $250. A ball screw for the cross slide might be as much as $100! The controller is $300 and the software is $140. The costs go up quite quickly! Getting very accurate and repeatable tool offsets is critical. General repeatable positioning is difficult without extensive modifications. Open loop motors seem quite a bit riskier for a CNC lathe vs a mill and I think having a missed step fault signal is much more important on a lathe. It is pretty easy to miss steps parting or drilling. I setup a consew motor to drive the spindle but I did not set it up with the acorn. I think it is great that you do not have to integrate the spindle motor controller and still run the acorn however you are not going to have the spindle stop on a fault which is a safety concern. The consew controller is also a bit of a PITA to reverse. I have not found a way to reverse via a controller easily. It also runs hot and a fan on the controller likely extends the live of the unit.
    Member mactec54's Avatar
    Jan 2005
    Default Re: centroid acorn and CNC 12 lathe pro review
    Quote Originally Posted by jschoch View Post
    Quite a right up, I guess you did not figure that the DB25 was only designed for the Gecko 540 direct connect, why would you need other Breakout Boards, everything you need to connect / wire is on the Board, the DB9 it a direct connect also for the encoder no Breakout Board needed, not sure why you would want to make a system more complicated than it has to be
    You are obvious not serious or you would have a dedicated computer, computer requirement's are needed for any machine control it does not matter what you run, Centroid just make it clear that there is a requirement, other's are hit and miss and users have constant computer problems
    You only miss steps if the motors are not tuned correctly, or are to small for the job you are using them on
    Mactec54
    Moderator cnckeith's Avatar
    Jun 2007
    I said you have a basic misunderstanding of tool offsets after trying many times to help you.. in writing and in videos, over the course of days... each time i explained the concept you kept coming back with the same misunderstanding, you were set on a idea of how tool offsets and reference positions work that was flawed, i tired and i tried to explain, it is simple, Tool offsets are the difference in length between a tool and a reference tool not to a reference position. which is a temporary position to make that measurement. not a permanent position..... but unfortunately you would not let go of preconceived notion and accept our logic. I have trained many users on this same method (which is pretty much the same on all cnc machine tools) with success. here it is again...
    video on Tool Offset setup is here.
    and once you have the tools setup in the tool libary operating an Acorn equipped lathe is seen in this video.
    Centroid CNC operator manual on Lathe Tool Offset setups is here.
    https://www.centroidcnc.com/centroid...nual-v4.14.pdf
    alternative to the Free Videos, Manuals and tech support provided on the forum... paid on site CNC training is available and well as one on one remote access Teamviwer training sessions.
    disabling the anti virus is a temporary thing to get up and running for a quick bench test to sort out the Ethernet communication and can be turned back on after bench testing has confirmed good connection between the CNCPC and the Acorn board.
    Mar 2018
    yup, this sums up my experience
    customer: "I looked around at videos and in the manual but I'd like to know how do the automatic tool measurment features work. they don't seem fully documented?"
    centroid: "please post a report.zip. here is a video on manual tool offset measurment, please read the manual"
    customer " thanks for the response but I did watch the video and I read the manual, I still don't understand how the automated tool measurement feature works. here is my guess .... is it correct?"
    centroid "you don't understand how tool offsets work, please watch the video"
    customer " i can work through the manual process but it doesn't seem like it fully maps to the automated process. here's my guess on how to do it, please take a look and let me know if it matches best practices"
    centroid no response
    customer posts a review of the product
    centroid "you don't understand how tool offsets work, we tried to explain to you how manual tool offset procedure works, please watch the video on the manual tool offset procedure"
    yikes....
    here is the full thread in question if anyone wants to read it before it gets deleted.
    tool z and x ref and offsets discussion for lathe auto tool touch off - Centroid Community CNC Support Forum
    Jan 2005
    yikes....
    The video explains it quit well compared to others, it is very basic, tool offsets, if you are not a machinist and you find this difficult then may be you chose the wrong hobby
    Mactec54
    Jan 2005
    And what supposed to be wrong with the thread, it looks normal to me, I only did the first page, any CNC setup and programing can take some time to get it together if you are new to this I would suggest you go to a trade school or a community collage and take some basic classes on lathe setup and machining
    You are asking about auto tool offset procedure, first you have to have a solid understanding of a manual tool offset before moving on to auto tool offset
    Mactec54
  7. #7
    Dec 2009
    Its been awhile since I visited this forum...
    I don't think the topic should read "review" rather it should read your "experience so far". I believe what this all boils down to is its new to you and you don't have a firm understanding yet. Centroid controls are industrial grade motion controllers. All Centroid specializes in is CNC Machine control. They have over 30 years experience with it. With Acorn, they understood they needed to reasonably simplify setup of the control, so they created a Wizard. I personally created many videos to try and help get someone up and running with the basics. That just gets your machine setup. There is no subsitute for the basic understanding of machine operation and CNC control. I think you are struggling with that. I would wager that if you take a step back, take small steps starting with the basics, you will grow to like and appreciate the Centroid Control. Just give it some time. If you have your machine setup correctly, you'll enjoy threading, tapping and constant surface speed on your lathe. Start to learn Intercon, the conversational programming included with CNC12.
    There are over 2000 Acorn units sold coming up on its 2nd anniversary on August 1. Its a robust control and Centroid is spending a lot of time on enhancing it. I jumped on board when I heard Centroid was going to do step and direction motion control again. Having the hardware and software come from the same vendor is huge in my opinion. There are a lot of people starting to do cool things with it.
    Give it some time to sink in, do some more learning, give it a chance. Continue to enjoy the hobby and the machines you've built!
    Marty
    martyscncgarage on YouTube
  8. #8
    Jun 2007
    hello. to all...here is link to the whole thread being quoted and you can decide for yourself about the Centroid CNC support community. Yikes! :-)
  9. #9
    Member Ntl's Avatar
    Aug 2018
    yikes....
    I just read through the thread and I'm at a loss to why you would flame Centroid and the forum? I also highly doubt it would be deleted since all your questions were answered and it might be helpful for others who are trying to use a probe on a lathe. I personally have never seen anyone use one on a desktop lathe and at some point in the future I'm planning on building a small metal lathe that will run on Centroid.
    I understand completely that the 400+ page manual is confusing to new users and it definitely takes prior cnc knowledge to understand completely. I'm still learning and taking baby steps making sure I fully understand what I'm trying to accomplish then moving on to the next thing. Maybe you should try what I have done and just start using the machine alot and learn the control software. Then it's much easier to start to do more advanced things such as editing the plc and writing macros once you start using the machine more frequently.
    I personally think part of the problem is that most people don't typically have access to industrial type controllers and they have a steeper learning curve. I think the manufacturers of industrial products have the assumption that the operator is experienced, or can afford to hire someone who is. I personally am thankful that I was able to purchase a industrial proven controller for roughly 430 bucks and am not going to complain if it takes me time to learn. I also know for a fact that any cnc machine with a industrial controller isn't going to be easy to learn if you aren't used to using one. I don't know what your experience level is but I'm assuming it's more on my level than the guys who were answering your questions and you should understand that those guys have forgotten more than guy's like us know about cnc.
    One last thing I only skimmed through your long post, but the fact that you went off about security shows me you didn't watch and read the instructions. If you did you would have known that once everything is installed that you can turn back on the firewall. It just makes you lose credibility with your ranting and makes me wonder what your motivation was with this thread?
    I just wanted to share my experiences with Centroid and hopefully it helps you out with some of your concerns.
    Dan
  10. #10
    Mar 2018
    I received a thoughtful reply to my specific questions yesterday from cncsnw. His response is what I would consider good support.
    He seems to be a centroid distributor as is Marty and Gary. They all seem to collaborate on providing support on the forums. It isn't clear to me if the distributor advice is official centroid advice.
    My motivation is to share my experiences with the product pro and con. For centroid I hope they can consider the feedback and take from it what they thin benefits their customers. For prospective customers I think they have good hardware that is fairly easy to setup for a hobby lathe..Some features are documented in great detail. Manual tool offsets consume 20 pages of the manual. Unfortunately automatic tool offsets only has 2 pages of information. I did not get a good feeling from the support process. That may not be important to many prospective customers. Based on all the posts from Centroid and affiliates I get the feeling that automatic tool offset features are not intended for hobby users and because there are many ways to do it they do not want to provide a prescriptive or detail how the 20 pages of manual process map to the automated process.
    The overwhelming feeling I have from the posts on this forum and Centroid's support forums is that Centroid and affiliates (cncnsw being the exception) generally don't think I have earned the right to use automated tool offset measurement or ask questions about it. My lack of industrial experience has me confused and that I should invest some time in learning about CNC at websites like CNC cookbook ( a great resource btw). I may need to go to a trade school, but in any case I should just plain old use the controller as much as I can so I can get experienced doing things manually. Then after that I'll be able to read the manual and watch videos on the manual process that teach me. With this experience under my belt my guesses will be better and I will not need to ask any more stupid questions like what exactly is a "x diam"?
    Extending this line of logic, maybe what I really should do is remove the CNC controller all together and just get all my CNC experience by doing manual lathe work.
    P.S.
    X Diam/Radius: This ?eld de?nes the diameter or radius from which the X o?sets of tools are to be measured. This diameter is usually created by a skim cut as part of the tool measuring procedure. (See the Procedures for Setting Tool O?sets section later in this chapter.) To set the X diameter ?eld, cursor over to the X o?set column and press F1 - X Diam. and follow the instructions.
  11. #11
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I wouldn't call it flaming at all. He's not allowed to share his experience?
    All controllers do basically the same thing. And the learning curve shouldn't be much different between a hobby control and a so called "industrial" control. Again, they all do the same thing.
    Do you realize that attacking users that are having problems isn't helping Centroid to sell more Acorns. Especially to beginners, that may have a lot of questions.
    UCCNC 2017 Screenset
  12. #12
    Jun 2015
    Sweden
    These Centroid people are good at marketing for sure (30years in business and most reliable manufacturer bla bla), but not so good in customer support as I see.
  13. #13
    Dec 2009
    Quote Originally Posted by OlfCNC View Post
    I would take exception with your statement. Are you basing it on personal experiece or are you basing it on one individual's experience?
    Marty
  14. #14
    Dec 2009
    Quote Originally Posted by ger21 View Post
    He most certainly can share his experience...not an issue at all
    Your statement "All controllers do basically the same thing. And the learning curve shouldn't be much different between a hobby control and a so called "industrial" control. Again, they all do the same thing."
    Yes, motion controllers do "basically" the same thing. BUT it is a piece of software and as with any software package an individual needs to learn how to use it, become accustomed to it. Fair statement?
    I will tell you that "under the hood" the software is a complex and powerful. You don't just jump into the PLC and start making changes without understanding the logic behind it.
    New users are welcome to post questions most certainly. How the questions are posted, the terminology used and the user's end result will help a reader to give good suggestions.
    I've personally gone above and beyond to help users with their problems once I was clear on what the issue was. I've even had one drop by the house with his backpanel all wired up! :-)
    All I'm suggesting is that once a new user gets through the wiring and configuration of the machine, they spend a little time getting used to the software and how it operates.
    I completely respect a user's choice in machine control. At the end of the day, they need to be happy with it and that it does what they need to. Its a great time to be working with CNC controls So much to choose from!
    Marty
  15. #15
    Member Ntl's Avatar
    Aug 2018
    How am I attacking anyone or being disrespectful in anyway Gerry? It's just my opinion and observation about what was written. I just pointed out that he didn't follow the instructions and the video. I apologise if it came across that way it wasn't my intention.
    I personally had much frustration while building my CNC do mainly to my lack of knowledge and CNC experience. The machine I chose to purchase didn't help matters either with adding to the frustration. So I get it completely maybe you missed that part of my reply that I'm not a CNC master, I'm new to the game as well.
    I read the original thread and he was receiving answers to his questions. He was getting upset that he didn't get answers fast enough and questioned every answer also wasn't happy with the help he received. This is the problem we face today instant gratification it's a blessing and a curse. I could understand if this was going on for months or even week's. Also as I said the manual is overwhelming and very detailed. From what I've seen with other controllers they have no where near as comprehensive of a manual or have no manual at all.
    The OP sounds like he's trying to write a new CNC12 manual for some reason. He also was requesting the current manual to be changed to his specs. You really should read the entire thread Gerry.
    As for all controllers doing the same thing, not true and from what I've seen the learning curve is not the same. I've been looking for a industrial mill and trust me the controllers are not the same as far as the learning curve goes.
    If my post was taken in a bad way it was not my intention and I apologise to the OP. I'm not trying to hurt anyone's feelings. I was just posting my personal perspective as a Centroid customer and user. I have zero to do with the company and my opinion won't affect sales, they have a great product and someone like me doesn't matter.
    Every company from Ford to Apple has happy customers and angry customers and everything in between. One person's opinion and experience is just that and there will always be different ones. If people decide they don't like something do what you have to do, just keep it real and honest.
    His opinion isn't any more valuable than mine or yours and at the end of the day good products sell. This isn't a energy drink that is 99% marketing, this is a performance based product. And you can trust me it performs, maybe one day you will give it a try Gerry. I know you can't make any screenshots but you might like it anyway if you try it.
    Dan
  16. #16
    Member mkelcy's Avatar
    Feb 2019
    I'm also a complete newbie to CNC who has elected to go with the Centroid Acorn for a router table, because it seemed the most robustly supported platform out there. In doing so, I elected to build my own controller and VFD enclosures, even though I'm otherwise going with a CNC Router Parts build. I'm still building my electronics and have the mechanicals sitting in the shop pending a significant reworking of shop space and dust collection. That said, I approach all of this with a degree of humility. If I have a question about my build or bench testing and I'm referred to materials for review to address an issue I'm having, I tend to exhaust the materials before going back to the forum, and then try to explain exactly what I'm not getting. I've read this thread with interest. In my experience, again as a complete newbie, the Centroid forum support has been simply outstanding, with extraordinarily experienced people (Kieth and Marty, to name two) who are ready, willing and able to help. We all like to support what we've purchased; I've yet to feel pulled to any other platform.
  17. #17
    Jun 2007
    over the weekend i shot about 8 hours of lathe tool setup raw video..using our in house Techno test bed lathe that now has clearpath axis motors..in the video i go through the tool offset method of using a reference tool and i use a automatic tool touch off device (the Centroid TT-2) to setup tools required to turn a demo part and create some 3/4-20 threads......it all has to be gone thru and edited up to turn it into a seamless step by step video... I had two cameras going and the screen capture software on the CNCPC at the same time so thats 24 hours of video to scrub thru...it is quite an editing job in front of me to splice it all together for continuity. the video will be posted in the video section of the Acorn forum found here... Acorn CNC Videos - Centroid Community CNC Support Forum along with all the others... and here on CNC Zone... in the mean time i've made some short videos with my cell phone that don't require any editing time... here are three of them.
    and the unedited test part run..
    and the quick overview video with demo of electronic transmission (G99)
  18. #18
    Sep 2017
    I have both a centeoid M400 and cnc 12 acorn boards between 4 machines. In general yes they do the same thing however my m400 has encoder feedback, uses dc servos, and more robust hardware. I have had issues with both systems including boards on both that had gone bad. It’s more painful when a servo goes out on the m400. I run ac servos with internal feedback on two of my acorn systems and steppers on another. The biggest difference is the use of servos over steppers in my opinion night and day. The learning curve is about the same on both and the m400 being integrated and centroid equipment seems it has other perks in reliability where a home built pc may have Windows configurations that can cause issues. Frankly despite some drawbacks I will likely stick with them for the cost benefits and keep spare parts on hand. In comparison to my fanuc I don’t think there is a comparison between machines. The fanuc is more complicated yet even more robust and for the most part it’s been completely trouble free. If budget were never a concern everything I have would be fanuc controlled even with the added complexities just because I want to assemble a machine or preferably purchase one and not have issues with it. It also always seems whenever I do assemble one they are different enough it’s never a back to back identical wiring for each so I feel like I kind of start over to some degree. Once you grasp centroid it’s Uber easy when the bugs are all worked out between software and hardware. Far as rewriting installation I think providing centroid with individual schematics would be nice so that they can offer up on the forum what others have done but by no means should they be having to change because of an individuals preference or build. I would like to try their oak sometime in the future but Linux cnc is just fine for that particular build I’d want to consider. Being we mainly drop a file on a usb and into the machine other than pp the end result is ultimately the same.
    Quote Originally Posted by Ntl View Post
    Dan
