Newbie Acorn and Rays feedback - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 36 of 36
Thread: Acorn and Rays feedback
  1. #25
    Jan 2005
    Default Re: Acorn and Rays feedback
    Quote Originally Posted by OlfCNC View Post
    Oh I thought that what I read is that the Acorn can control 4 axis only, so how is the above video relevant?
    By "dynamic" I ment how a company acts not their control.
    What are they offering with the Acorn that other controls like Mach3, UCCNC, LinuxCNC can't do?
    Of course it is relevant same software different hardware
    So why such a stupid question the Company acts just like any other company, have great support for there products, they would not of been in business for 40 years if they had not
    What do they offer, better control software, the main core of any control, the Acorn which was only hatched for the hobby market, which supports Lathe as well as Mills / Routers
    Mactec54
  2. #26
    Jun 2015
    Sweden
    Hmm, I did not hear that they act so nicely with customers.
    I was curious what exactly is better in their control? What I see is that their acorn control has much less functionality than Mach3/4, LinuxCNC, PlanetCNC, UCCNC. The acorn control only 4 axis for more cost than the other softwares which all support 6 axis.
    The acorn can't be customised, everything is "hardwired" while you can customise things with all of the other software options.
    And their support is not free while those other software producers give free and friendly support.
    I don't see these things so much better than the other vendors.
  3. #27
    Jan 2010
    RLWoodie,
    I attended Cronulla High School on the south end of Sydney from 1967 through 1970, so old farts can learn this stuff too.
    Others, it is often left out of the conversation that the Acorn isn't the only controller board that Centroid offers - it's simply their newest one and was developed for the hobby/DIY community.
    And to add to the confusion, Centroid announced recently that they just celebrated their 31st anniversary in business - right in the middle of 20 and 40 - LOL
    I ran Mach3 on Gecko G540's for 5 years, but have given up on Mach3. The last update was over 6 years ago, so it isn't changing. Centroid, and others, have developed new tool paths and techniques, like adaptive tool paths and others. They regularly release new software updates for free. 12.4.18 was just released last week..
    As for the 5-axis argument, my understanding is that the U.S. government restricts the export of 5-axis technology, hence the restriction on the Acorn board. However, with the last and this most recent release, you can in fact slave two steppers off of one axis for a dual drive gantry and still have the 4th axis available for a spindle. It has to do with daisy chaining step and dir signals and some software options for homing the gantry.
    In any case, RLWoodie, I think you'll like Centroid/Acorn if you decide to go down that path.
    Good on 'ya, mate!
  4. #28
    Jun 2015
    Sweden
    I don't think that it is USA export restriction, because Mach3 is also a USA software and can run 6 axis and is sold worldwide.
  5. #29
    Aug 2016
    Mach3 is taking their chances, probably because they don't want to spend months wading through the ridiculous pile of regulations.
    If you want to know, you can start researching EAR part 774. You will likely have to go through several related documents before making any sense of it.
    https://www.bis.doc.gov/index.php/re...egulations-ear
  6. #30
    Jan 2005
    Mach3 is just Software
    Centroid's Software does up to 8 axes and does a much better job with there software than Mach3
    The Acorn can be customized to do what ever you want, tool changer, lathe turret, auto lube, coolant, 3D digital probing auto tool offsets and anything you can dream up, 5 axes no but was not designed to do that, 4 Axes is all most need the rest can be done through I/0 , it can be direct connected to the popular G540 and any other PP Breakout Boards it you wanted to do something different
    Mactec54
  7. #31
    Jun 2015
    Sweden
    Yes, but it can control up to 6 axis even without additional hardware say LPT port.
  8. #32
    Jan 2005
    Yes Mach3 has been an amazing control software I use it on one machine, it has helped thousands of user get into CNC machining all over the world and will still be used for years to come
    Mactec54
  9. #33
    Activation process metalmayhem's Avatar
    Jun 2018
    are you running acorn on a router or a mill that was previously running mach ? I'm curious how much of an improvement you've found in the control above mach or the others
  10. #34
    Jan 2005
    Quote Originally Posted by metalmayhem View Post
    I'm just doing test right now, before it will be on our machines, have not found any problems with it but time will tell, I run a lot of different controls and software but so far it is at the top of the list
    Mactec54
  11. #35
    Apr 2011
    for G E Brown
    Nice to hear about your time in Cronulla. I originate from WA and went to Northam High School 1948-1951. Northam is about 100 ks east of Perth.
    I am pretty well convinced it will be Acorn but still fiddling with Mach 3 Turning Wizard because I design and build electromagnetic clocks, work in wood and brass, and am looking for some unique brass decorations to increase the wow factor..
    Woodie
  12. #36
    Jun 2017
    I have gone from Mach3 to UCCNC. Might have a look at acorn some day
