Centroid does provide a Future MPG for $335 but it will require the legacy adapter box for $220 in order to be able to connect to that 8-pin connector. Unfortunately, you won't be able to install a non-Centroid MPG to that system as the MPGs on those systems had a Centroid specific communications protocol. The other option would be if you can find someone who has one of the MPGs in your photos.
