Those are not relays.
Those are just terminals, for connecting one wire to another.
They are also used to connect multiple wires together, using the jumper bars that are installed horizontally in the middle (joining multiple adjacent terminal blocks together).
There is a slight possibility that the four larger beige ones are fuse holders, but only if there is a removable piece you can pull out of the middle, with a fuse in it.
