After you have digitized a file, you just need to press F6(Dig to CAD) in order to create the point cloud file. Depending on the version of software that file will either have a .txt or .doc extension but it will have the same name as the name of your digitized file. You would then import that point cloud file, .txt or .doc, into your CAD/CAM software. The only thing is that your CAD/CAM software has to have the ability to import point cloud files. I know that some CAD/CAM systems do not have that ability.
