Upgrading CNC7 to CNC10 - Project Log - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Upgrading CNC7 to CNC10 - Project Log
  1. #21
    Aug 2009
    Default Re: Upgrading CNC7 to CNC10 - Project Log
    Thanks for that Keith, I certainly did not look at that option and it would have been within my budget. Still not for me (especially at this point) as I'll be selling sometime in the next year but before the decision to sell was made I might have gone that route. I'll keep that in mind if I keep the router or get creative in expanding the router table.
    Graham
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  2. #22
    Moderator cnckeith's Avatar
    Jun 2007
    check out this photo album of centroid mpu11 legacy add upgrade images..
    https://picasaweb.google.com/1066489...idCNCControls#
  3. #23
    Aug 2009
    Quote Originally Posted by gfacer2 View Post
    Ok so another issue to hopefully work through - the jog dial on the pendant is not working. I hope that is a parameter setting but haven't had time to determine it yet.
    Problem was a loose connection between the keyboard and chair as they say (me).... I think on the old system the mpg button defaulted to on and now I have to press the mpg button first.
  4. #24
    Aug 2009
    Ok - a little resurrection on this thread. I did sell the machine (to a customer 2 buildings over) and we moved it with a fork lift. A couple of quirks as I revived it today...
    1) is only worth mentioning in passing as it is not really an issue of mine - the vacuum relay now only goes on when the metal electrical box is not fully closed. Consistently fine if it is ajar/not fully closed but not if it is fully closed. I think it might be a magnetic issue but something for the electrician to figure out. Also Aux 3 now seems to drop the tool - maybe it always did but I don't recall that.
    2) I am more concerned about. The Controller computer has twice rebooted randomly - once just while we were setting tools up etc and once when it was running a program (air cutting). 1 Weird thing is that the job did not stop - I thought it would literally have to as the power relay for the motors would have clicked off. I am hoping that it may have been an issue with a loose sync cable (fiber optic) as the cpu7 board has a broken clip on the fiberoptic input for the sync cable. I've had an issue before but I don't remember how it manifested itself and at any rate its now on a linux 2.7 system rather than DOS so it might be different.
    I wasn't able to get it to repeat after securing the sync cable (by taping it to the wire next to it that is clipped in) but not sure if I'm just lucky at this point.
    So any thoughts on whether that might have been the cause? I'll see next time I am with him trying a job but thought I'd throw it out there.
  5. #25
    Feb 2008
    No, the SYNC fiber cannot cause the computer to spontaneously reboot.
    That type of issue is usually due to a faulty PC power supply; overheating CPU (check heat sink & fan); faulty motherboard; or momentary interruption of the 120VAC supply.
    It is also possible something is momentarily shorting the PC's 5VDC bus, which passes through the CPU7/CPU10 board to the jog panel and to the encoders. Check your jog pendant and encoder cables for damage or faulty connections.
  6. #26
    Aug 2009
    OK thanks, I'll give it a look over and see what might have loosened on the short bumpy trip over.
    Sent from my LG-D852 using Tapatalk
  7. #27
    Activation process Abdullah00671's Avatar
    Jun 2018
    Hello dears
    I need a help.I know this post is too old may any person
    Read this post or not...anyway
    Today I am upgrading my centroidcnc DOS system
    With linux.I am facing a boot problem. I attached
    It's pictures.
    Attached Thumbnails Attached Thumbnails Upgrading CNC7 to CNC10 - Project Log-15766731017893840953796699136305-jpg   Upgrading CNC7 to CNC10 - Project Log-15766731173586510539121653522173-jpg
  8. #28
    Jun 2018
    Hi dears..
    I need a help. I am trying to upgrade my cnc7
    With Cnc10..old operating system was Dos now I am
    Try with Linux but facing a boot problem.i attached
    Pictures
    Attached Thumbnails Attached Thumbnails Upgrading CNC7 to CNC10 - Project Log-15766735760677517671643712929661-jpg   Upgrading CNC7 to CNC10 - Project Log-15766736006593334247401312304717-jpg
  9. #29
    Jun 2018
    I
  10. #30
    Jun 2018
    Hi dears..
    I know this post is too old but may be able to get some help.
    I upgrade my Dos cnc7 system to Cnc10 Linux..I am facing some error.
    "Inconsistent filesystem structure"
    Using m400 original pcm4860 mother board.
  11. #31
    Jun 2007
    Quote Originally Posted by Abdullah00671 View Post
    Hi dears..
    hello. centroid cnc technical support available for free here.. https://centroidcncforum.com/index.p...a771727ef260cd
