Yesterday I made the the first casting with a new mold I machined. The mold will form a 2' long by 1.75" diameter rod. The mold was machined from thick walled (3/8" wall thickness) tubing. This thickness affords a 1/4" lip to seal the seam. The mold has a volume of ~60 cubic inches. I use graphite as a release agent to aid in the extraction of the ingot.
I only noticed one hairline crack about 4" from the top of the pour. I typically find these to be surficial and no more than a mm deep.
I will let the ingot cure for about three weeks before using it in the lathe.
Prior to using this split mold I used to have to press out the ingots.
- Need Help!- Cannon Wheel Casting Mold
- Newbie- Metal Casting or Mold Making?
- Permanent Mold Casting
- Need Help!- One-use casting mold
