Need Z-homing script, everytime I try to home the Z it goes past the aluminum sensor!!!! Need a script to automatically make the z go up .325" after contact with aluminum surface. I'm using an aligator clip on the bit and the other end of the sensor is attached to a piece of aluminum angle on the work surface to home the z. Thanks in advance.
