- Can I engrave a face model by the 3D models from 3D scanner?
Re: Can I engrave a face model by the 3D models from 3D scanner?
Your file will be quite deep, necessitating the addition of a base plane, which will add a significant amount of labor to your plate. If the 3D object is too deep for your system to handle, you can try scaling it down such that its depth is less than the thickness of your board.
mini crossword
- You may not post replies
- You may not edit your posts
Forum Rules
