HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP
  1. #21
    Feb 2018
    Quote Originally Posted by Al_The_Man View Post
    Incidentally many 3ph NFB's (Non-Fused Breakers) need to see current through all three phase connections, therefore it is common industrial practice to loop one of the hot (L1 or L2) back through from the outer to centre connection when using it for 1ph .
    Also if using the Phase Perfect I would ensure that any non 3ph loads, i,e, single phase transformers etc, are fed off of the 2phases derived from L1, L2 and not the generated phase.
    Hey Al, thanks for replying.
    I have my supply coming in to a splitter box. From there it feeds a 1 phase compressor and the second out put would feed the Phase Perfect unit. The Phase Perfect would only be used to power the 15hp CNC. Nothing else.
    In your opinion is a Digital unit like Phase Perfect worth the cost compared to a RPC like American Rotary. It's a big additional cost that I was not expecting but don't want issues either.
    Thanks.
  2. #22
    Dec 2003
    Default Re: HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP
    The Phase Perfect is obviously the better choice, it retains much more balance on the generated phase compared to VFD which can in some cases drop voltage on load.
    Although for RPC's I only have experience building and tuning them, not the off the shelf versions.
    The single phase loads I refered to would be in the control cabinet, motion controller etc , not external ones.
    Incidentally what is the nature of the 3ph loads, if only for the spindle, some have used a standard VFD for this and fed the rest from the 240v 1 phase.
    Member mactec54's Avatar
    Jan 2005
    Not in this case the Hp is to large on this machine for a Single phase connection
    Mactec54
  4. #24
    Jan 2005
    Quote Originally Posted by CCF_CUSTOMS View Post
    Thanks.
    Night and day better, some machining centers don't like the RPC even the CNC rated units, you should talk to Haas as they do this all the time, they will give you the best answer, as to what to use
    Mactec54
