Thank you sir, for post this review.
working on client's sample.
just done.
here is the video.
Well I finally got my Machine hooked up and running after some delay because of damage during shipping but Jack Dong from Shandong Yishun CNC Machinery CO., Ltd. where I purchased it from made sure all parts were replaced and made sure I was happy with everything, I had to install he gantry because it taken off to ship, they walked through every step of the way, after everything that was broke was replaced one of their engineers connected to my pc via Team viewer and mad all the necessary configurations to motors and homing limits and stayed till was happy with everything, I hope to upload a video soon of it running just need a little practice an busy with the honey do list, Over all my experience with Jack Dong as very Good I would recommend him to anyone, the overall of the machine I would rate an 8, there are a few small things such wrong washers being used in hold down slots , not a lot of English manuals, cables and wiring running through holes that were cut that have very rough edge's and should have been protected better, lack of fans in the cabinet cooling, I think its a very solid machine, may not be top of the line but I did not pay top of line price, I have included a few pics If anyone has any comments I would be glad to here them or question's I will try to answer them
Steve
YS-1325 CNC Router wood working
1, T-Slot Table for 5/16 t bolt
2, Transmisson : XY Axis Rack Gear Z Axis German Neef Ballscrew
3, XYZ Axis Square rail: 25mm Taiwan HIWIN Square Rail
4, 5.5kw Water cool spindle
5, Delta Inverter
6, Yako drivers
7, 450c Stepper Motor
8, Manual Oil System
9, Full Sets of Collets ER20
10, Full Sets of Wood working cutter
11, rotary Diameter 340mm
12 Mach 3 with all motor setting pre installed
13, 3hp dust collector
14 100' of 6" anti staic hose for dust collector
15 dust boot for spindle
just done.
here is the video.
Shandong Yishun CNC Machinery Co.,Ltd Email: JACK.DONG@YSCNCROUTER.COM
Whats App&Mobile: 0086-137-9314-0576 Skype: YSCNC05
Hey Steve, I wanted to see how you were making out with your machine, I was looking at purchasing a 1325 very similar specs to yours?
We have 1325 machine in Chicago
https://www.automationtechnologiesin...5-cnc-machine/
USA Tech Support: 847-984-0882
1: Brand New CNC Router Engraving Machine ,T slot, Vacuum Table, Rack/Pinion
2: 3 .2 KW Water Cooled Spindle + 3.2 KW 400Hz Variable Frequency Driver
3: We changed this Machine to Mach3 or 4 Control , DB25 Breakout board with Relay and Spindle control with Ethernet You can use 32 bit or 64 bit connection. or we can update to Centroid Software
4: Mach3 Software is not included
X,Y axis working area
1300mm*2500mm (51.2" x 98.4")
Z axis working area
200mm ( about 8")
Table size
1440mm*3000mm
Max. speed
14m/Min
Max. working speed
12m/Min
Working accuracy
0.01mm
Repositioning accuracy
0.05mm
Feeding height
120mm
Command code
G code
Software
working with Mach3 software with Windows 64 or 32 bit
Working power
4000W
Working voltage
AC220V/50HZ/60HZ
Water Cooled Spindle power
3.2 KW
Spindle running speed
8000-24000
Spindle Power Motor: 3.2KW, Water-Cooled, ER20 Collet Chuck
Spindle Speed: 0-24000 rpm With VFD, AC220V/50Hz/60HZ
X, Y, Z axis driver: Stepper Motor Driver, NEMA34 Stepper Motor
X, Y Z Limit Switch
E- Stop, Z Height Probe
X Axis: Rack Pinion
Y Axis: helical rack and pinion with 5:1 Gearhead, See Pictures
Z Axis 20m Linear Rail with 25mm Ballscrew
Attachment 402284Attachment 402284
