Need Help! Help We had a problem with the machine Mikron HSM 700
Results 1 to 4 of 4
Thread: Help We had a problem with the machine Mikron HSM 700
    Dec 2012
    ukraine
    Default Help We had a problem with the machine Mikron HSM 700
    Help We had a problem with the machine Mikron HSM 700-imag1648-jpg
    We were advised to turn to you
    The problem is in the attached file which is sent to you.
    I understand that we need a Root password for system reboot
    See attached photos
    Are you able to help us'll be very grateful
    Sep 2016
    Bosnia And Herzegovina
    Default Re: Help We had a problem with the machine Mikron HSM 700
    Dear sirs do you have postprocesor for ATEK PLUS.
    Is it possyble to send me.
    Best regards
    office @profimold.com
    Moderator
    Apr 2003
    You'll to get this post processor from the CAD/CAM software supplier or ATEK directly.
    Tech Support
    CamSoft Corp.
    support@camsoftcorp.com
    PH 951-674-8100
    Fax 951-674-3110
    CNC Controller, PC Based CNC Controls
    *Registered User* EdgeMaster's Avatar
    Dec 2018
    Hello.
    Clone the HDD to a image with DD or better.
    Its possible, the HDD had bad sector.
    Best regards.
