A calculator for measuring bore diameters using three gage pins
Results 1 to 2 of 2
Thread: A calculator for measuring bore diameters using three gage pins
    Sep 2017
    Default A calculator for measuring bore diameters using three gage pins
    After some discussion on another machining forum, I created a web-based calculator for calculating the diameter of a bore based on the diameters of three gage pins (or any other cylinder) that fit into it.
    It's free, open source software that I built as a side project in my spare time. I wanted to show it to the CNCZone community, hopefully it's of use to someone!
    You can access it here: https://www.holecalc.com
    Let me know if you have any feedback or issues!
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: A calculator for measuring bore diameters using three gage pins
    hy this method was heavily used into inspection areas, that used to use sets of gage pins with increments of 0.01, 0.005, or even less; required hand's sensitivity
    method was tough, but it started to loose ground a few decades ago
    what you did is ok, just keep it up if you like to go that way
    if you wish to go futher, "down the hole", then try to think about calculating a diameter, using :
    ... 3 points from a ( normal ) probe
    ... 2 points from a probe that is sensitive to cosine directions / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
