First Test Indicator
Results 1 to 4 of 4
Thread: First Test Indicator
    May 2010
    Default First Test Indicator
    I purchased my first test indicator and was wondering why the arrow isn't pointing straight up (refer to attachment)? I know you can move the face, but no matter what I do, if I move the measuring point through it's full range of motions, if I release it, the arrow always points to the same off centre location.
    Attached Thumbnails Attached Thumbnails First Test Indicator-20180601_175954-jpg
    Apr 2013
    Sweden
    Default Re: First Test Indicator
    There is no specific reason. It's just been made this way, and it doesn't actually makes a difference since you can rotate the dial to zero.
    https://www.youtube.com/c/AdaptingCamera/videos
    https://adapting-camera.blogspot.com
    Mar 2017
    its scrap.
    please send it to me so i can make sure its disposed of properly
    actually it is offset just slightly in the unloaded state. So that when you actually load it against an article to interrogate, the pointer can be at 12:00.
    you buyin that?
    May 2010
    Quote Originally Posted by generaldisarray View Post
    its scrap.
    I knew someone was going to say that.
    you buyin that?
    Ah I think I see, makes sense.
