Newbie cadkey,99,98,97 lost serial codes
Results 1 to 5 of 5
Thread: cadkey,99,98,97 lost serial codes
    Apr 2008
    Default cadkey,99,98,97 lost serial codes
    i have several cadkey versions but i noly had the code# for 97.
    lost it......
    is there anyway to get new serial codes ro retrieve the old ones?
    any help would be appriciated...thanx
    chuck
    Member moldcore's Avatar
    Apr 2003
    What do you mean by serial numbers and what are they used for? If you’re looking for license files to activate your program you need to contact your VAR.
    May 2006
    Default I have one for 97
    I purchased a Cadkey 97. Private message me it may work, Why not just use Cadkey 98 or better yet 19? I use 19 to make the bucks reliably.
    Been doing this too long
    Sep 2004
    us
    Quote Originally Posted by chaz6966 View Post
    lost it......
    chuck
    You don't need the serial codes. Just load CK99, When the window comes up for you to enter the serial no, and key code, click cancel, and then it should load up just fine.
    jmeverton's Avatar
    May 2021
    Default Re: cadkey,99,98,97 lost serial codes
    I open up my CadKey98 software and it requests serial code and code key. I have hundreds of 3D drawings on the C: drive and just need to get at them.
    How do I load the CK99 short cut?
    John
