- Just In New Proton Z axis ( plus - Retrofit info)
Specs
1606 true ball screw (lubed, double seal, double anchored)
25MM rails (Lubed, twin triple seal with scraper on each)
Servo soft limits available
Magnetic breakaway (MAG-LOK v.2.)
Powder coated sheet metal enclosure with quick access
5/8" thick
Torch bodies up to 2.00"
Integrated with 800 RPM motor (When installed on Proton machine)
Up to 4.5hp router capable
Angular compass up to 65 degrees (from 0 to 60 degree angle cuts (infinite ratio)) available
Twin pocket auxiliary tool pockets with 3 tapped holes for rigid tool bracket mounting
Retrofit Proton Z axis includes all the the above except
- - - Updated - - -
This section intentionally left blank for picture reserve
Re: New Proton Z axis ( plus - Retrofit info)
- You may not post replies
- You may not edit your posts
Forum Rules
