Repair dc driver, manual, circuit diagram, Bridgeport EZ Path I
Results 1 to 4 of 4
Thread: Repair dc driver, manual, circuit diagram, Bridgeport EZ Path I
    Member aldoo's Avatar
    Jul 2018
    Default Repair dc driver, manual, circuit diagram, Bridgeport EZ Path I
    Hi, I have a lathe EZ Path I of Bridgeport from 1991. Actually we have troubles with the driver. We have the Driver Fault Alarm. When we check it the intern fuse was blown, we changing it, but when turned on the machine three mosfets was destroyed and the fuse too. We changing the fuse and compatibly mosfets, conecting the drive without the motor armature, tachometer and encoder with the supply all ok, but when connecting the tachometer and encoder without motor armature the new fuse and the three mosfet blowed again.
    We do not know what is happeing. Some one have had this trouble? or maybe some one have the electronic diafram of the driver?
    I attached some images of the driver.
    Attached Thumbnails Attached Thumbnails Repair dc driver, manual, circuit diagram, Bridgeport EZ Path I-img_20190907_103327-jpg
    Feb 2008
    Default Re: Repair dc driver, manual, circuit diagram, Bridgeport EZ Path I
    Quote Originally Posted by aldoo View Post
    Just a general power MOSFET note:
    When MOSFETs fail they almost always short their Gate to the Source or Drain (most often both)
    This tends to destroy the gate drive circuitry so simply replacing the MOSFETs without checking
    that the gate drive circuitry is working is liable to result in more fireworks...
    Jul 2018
    Thanks for the fast reply.
    With the new mosfets we have not connected the drive and looking for driver electronic diagram to check it, but unsuccessful.
    Jul 2018
    Excuse me, I know drivers with four mosfet, but this has six, do you know what kind of driver is it?
