- 2001 Bridgeport ezpathe IIISD lathe GP error on program load?
Recently got a 2001 Bridgeport ezpathe IIISD lathe. Its now installed and checked out/adjusted and Im trying to load programs. I can view txt programs generated from cam but when I try to execute a "RUN" command to load them into memory, I get a "GP error" and the control reboots. This does not happen to the few PGM programs that are resident on the C drive from the previous owner. I tried running cam programs from the A drive and tried copying them to the C drive and still same error.
(forgot to add that I can upload the previous owners PGM programs and run them just fine)
Heres the test program Im trying to run. Its supposed to be a post for this later version of the ezpath control.
N0001 T02/02 M6 'TOOL CHANGE ID=2
N0006 M11
N0011 G38 S800
N0016 G37 S825 'FORWARD RPM = 800
N0021 G90 G0 X.9 Z.3 M8
N0026 Z.0101
N0031 G1 X.718 F.007
N0036 X.658
N0041 Z-.3469
N0046 X.718
N0051 G0 Z.0101
N0056 G1 X.658
N0061 X.598
N0066 Z-.191
N0071 G2 X.62 Z-.232 I.456 K-.232
N0076 G1 Z-.3469
N0081 X.658
N0086 G0 Z.0101
N0091 G1 X.598
N0096 X.538
N0101 Z-.161
N0106 G2 X.598 Z-.191 I.456 K-.232
N0111 G0 Z.0101
N0116 G1 X.538
N0121 X.478
N0126 Z-.1507
N0131 G2 X.538 Z-.161 I.456 K-.232
N0136 G0 Z.0101
N0141 G1 X.478
N0146 X.418
N0151 Z-.15
N0156 X.456
N0161 G2 X.478 Z-.1507 I.456 K-.232
N0166 G0 Z.0101
N0171 G1 X.418
N0176 X.358
N0181 Z-.15
N0186 X.418
N0191 G0 Z.0101
N0196 G1 X.358
N0201 X.298
N0206 Z-.0707
N0211 G2 X.326 Z-.102 I.242 K-.102
N0216 G1 Z-.15
N0221 X.358
N0226 G0 Z.0101
N0231 G1 X.298
N0236 X.238
N0241 Z.0002
N0246 G2 X.268 Z-.032 I.184 K-.032
N0251 G1 Z-.0621
N0256 G2 X.298 Z-.0707 I.242 K-.102
N0261 G0 Z.0101
N0266 G1 X.238
N0271 X.178
N0276 Z.01
N0281 X.184
N0286 G2 X.238 Z.0002 I.184 K-.032
N0291 G0 Z.0101
N0296 G1 X.178
N0301 X.118
N0306 Z.01
N0311 X.178
N0316 G0 Z.0101
N0321 G1 X.118
N0326 X.058
N0331 Z.01
N0336 X.118
N0341 G0 Z.0101
N0346 G1 X.058
N0351 X-.002
N0356 Z.01
N0361 X.058
N0366 G0 Z.0101
N0371 G1 X-.002
N0376 X-.062
N0381 Z.01
N0386 X-.002
N0391 G0 Z.0101
N0396 G1 X-.062
N0401 X-.064
N0406 Z.01
N0411 X-.062
N0416 G0 X.9
N0421 G38 S700
N0426 Z-.002
N0431 G1 X-.164
N0436 X-.064
N0441 X.184
N0446 G2 X.244 Z-.032 I.184 K-.032
N0451 G1 Z-.072
N0456 G2 X.302 Z-.102 I.242 K-.102
N0461 G1 Z-.162
N0466 X.456
N0471 G2 X.596 Z-.232 I.456 K-.232
N0476 G1 Z-.3505
N0481 Z-.4005
N0486 G0 X.9
N0491 Z.3
N0496 X9. Z12. M9
N0501 T05/05 M6 'TOOL CHANGE ID=5
N0506 M11
N0511 G36 S600 'FORWARD RPM = 600
N0516 G90 G0 X0 Z.3 M8
N0521 Z.1
N0526 G1 Z-.07 F.001
N0531 G0 Z.3
N0536 X9. Z12. M9
N0541 M2
Re: 2001 Bridgeport ezpathe IIISD lathe GP error on program load?
Weird. Bad syntax is the cause. Unless there is an X and a Z move on every line, it will crash the OS. This post was supposed to work on the later controls....
I see that bridgeport romi powerpath controls can interpret gcode differently depending on what characters are at the beginning of the program "&" changes to fanuc mode, "&" causes the control to accept bridgeport mode cgode. Anyone know if thats true of the last gen ezpath controls? Ive got a : at the beginning of my output.
Also, Im thinking there must be a control parameter that changes cgode interpretation, otherwise I doubt that all 4 of the ezpath posts in the gibbscam library would post the same non working code on an ezpath.
Wow, for a machine thats this common, seems like theres literally no knowledge about the control gcode requirements out there. So no one has ever determined what any of the parameters on this control actually do? I checked with EMI and even they dont know anything about the parameter definitions. Sad to be held up by what is likely a simple parameter change. Otherwise seems like a great machine.
What I would do is load a good running pgm program; then hit the - (minus) key once to see the gcode. Compare some of the code to the problem txt code and see if there is any obvious difference in the program header, commands etc. Press the 1 key to scroll down through the code.
Another thing that can happen is unseen format tags and styles or other coding schemes can be added to the file. See here where I explained it a bit.
I did try that but even if I saved one of the previous owners PGM programs as a gcode format txt, and changed just one line to take X or Z to another line, it would crash the control on load! With no changes the converted cgode would run perfectly.
So I ended up getting a couple working gibbs ezpath posts, one for the conversational output and one for Gcode. Me and a programmer buddy made a stab at changing the closest gibbs post I had earlier with compost and managed to get the approach line changed but starting from zero experience writing posts, seemed like it was going to be a long slog.
Works great now, at least for the couple test parts I made with threading, contours, roughing, finishing. Even the duplomatic tool changer works with the tool change commands.
- You may not post replies
- You may not edit your posts
Forum Rules
