- Bridgeport VMC 3016 4th axis help
I have a 2000 Bridgeport VMC 3016 that has a non functioning 4th axis. I've been working on the unit and have come to conclude the biggest problem I'm facing is with the cable assembly. The 4th axis was partially disassembled when I got the machine and there are some wires that were disconnected and not labelled. Attached are pics of the cable assembly along with the disconnected wires. Can anyone please help me determine where the wires attach? Is there anywhere I can get a new cable assembly? Does someone out there have the same 4th axis who can give me pics showing where the loose wires connect? The 4th axis itself is a Bridgeport Torq-Cut with a Troyke rotary table, not the greatest out there but it should be fine for what I want to do.
Thanks,
Jeff / PJM
- You may not post replies
- You may not edit your posts
Forum Rules
