Bridgeport mill table screw movement
Results 1 to 3 of 3
Thread: Bridgeport mill table screw movement
    Member Nigh's Avatar
    Dec 2022
    Default Bridgeport mill table screw movement
    We have an oldish (1950s?) vertical mill. When manually moving the table left to right or right to left, the L.H. handle is permanently engaged. The R.H. handle is disengaged until you push, pull or rotate the part of the handle that you hold. It will then engage & move the table. Is it possible to change/adjust this R.H. handle so that it is permanently engaged? Having to hold the handle into engagement is awkward if you are also trying to look closely at the workpiece to make small adjustments.
    Member gabedrummin's Avatar
    Aug 2008
    united sates
    Default Re: Bridgeport mill table screw movement
    That is a safety handle for the power . It can be replaced for a standard handle.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Nigh View Post
    You can take the spring out and add a spacer on the other side, to engage it full time.
    Mactec54
