Bridgeport Interact 720 Z Axis Motor Removal
Results 1 to 3 of 3
Thread: Bridgeport Interact 720 Z Axis Motor Removal
    Jun 2011
    germany
    Default Bridgeport Interact 720 Z Axis Motor Removal
    Hi folks , I need to move out of my old workshop and into a new ,and warmer one ! And I need to remove the Z Axis Fanuc motor on top , a damn heavy piece of metal ( it dont fit under the door frame . I did this when I bought it 15 years ago and cant think how the hell I did it ! Is it just the 4 screws ,bolts , out and supprt the spindle, lift and crack it off the shaft ? I thought I would ask a grown up before I do the other thing ! All the best stay safe all you lot , Harry
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Bridgeport Interact 720 Z Axis Motor Removal
    ..most likely has a Flex Coupler from motor to ball screw. Finger type
    Jun 2011
    germany
    Hi there ,that was ther first clue the second was from Carrie at Repair Zone ,and this is what I found !! 12 of the smallest screws painted over and hiding a thin metal cover ! And heres the coupling ! Job done ! Thank you for the tip Harry Bridgeport Interact 720 Z Axis Motor Removal-thumbnail-1-jpgBridgeport Interact 720 Z Axis Motor Removal-thumbnail-2-jpgBridgeport Interact 720 Z Axis Motor Removal-thumbnail-jpgBridgeport Interact 720 Z Axis Motor Removal-thumbnail-5-jpgBridgeport Interact 720 Z Axis Motor Removal-thumbnail-4-jpgBridgeport Interact 720 Z Axis Motor Removal-thumbnail-7-jpg REPAIR ZONE
