Bridgeport EZ Path
Results 1 to 5 of 5
Thread: Bridgeport EZ Path
    Member wwooley316's Avatar
    Mar 2020
    Default Bridgeport EZ Path
    I have a bridgeport machine that when you power it up, the table will move all the way to one side & you have to power it down to stop it. What could the issue be?
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Bridgeport EZ Path
    assuming you have DC Servo Amp's if, Yes what Model number Amp's?...Tach wires backwards...Motor wires backwards...has someone been doing any wiring when the problem started? Has the machine ever run correctly?
    Mar 2020
    It is DC and no one has worked on it. It is a machine that seldom gets used.
    Member StrawberryBoi's Avatar
    Aug 2021
    Quote Originally Posted by wwooley316 View Post
    A good place to start is to probe the connection to the relevant servo and see if it's shorted to the DC bus.
    Jun 2004
    hi, check your limit switches, i had an eztrak that did the same thing and i found out that i had a limit switch that was stuck .
Bridgeport EZ Path
Bridgeport EZ Path
