Help needs in haidenhain TNC 151
Results 1 to 9 of 9
Thread: Help needs in haidenhain TNC 151
    Member moghul's Avatar
    Apr 2006
    PAKISTAN
    Default Help needs in haidenhain TNC 151
    Hi
    I have problem in TNC 151. Machine axis goes to reference point normal but after reference it vibrates heavy and gross positioning error.
    Any kind of help appreciate.
    M. Shabbir Mughal
    Jan 2005
    us
    Default Re: Help needs in haidenhain TNC 151
    Probably tach needs adjusting
    what machine is it on with which servo drives?
    Apr 2006
    PAKISTAN
    Quote Originally Posted by gus View Post
    all axis.
    if i change control then normal.
    Jan 2005
    us
    You response makes no sense
    No one can help if you do no give information
    Apr 2006
    PAKISTAN
    hi
    what type info u need?
    all axis have huge vibration.
    when going to ref its normal. after ref complete motor vibrate and gross positioning d error.
    i checked all axis separately.
    Jan 2005
    us
    SO repeat yourself without answering the questions asked
    What machine and what servo amps
    When homing the control just puts out a set voltage to move the axis in a direction. It does not close the positioning loop until it hits the trip dog for the axis position. Your machine cannot control the position loop, tach adjustment, gain adjustment,
    Start by answering the questions
    Also, has this machine run for you before,?
    Did you lose the parameters?
  7. #7
    Apr 2006
    PAKISTAN
    hi
    yes i know all that for this controller. when it goes to close loop it will in problem. i have checked the teco and adjusted but same . and also set the gain in parameter n on drive. but same
    tr one more tomorrow then update here the results.
  8. #8
    Jun 2017
    Portugal
    Quote Originally Posted by moghul View Post
    hi
    how to resolve that?
    i have thesame problem. but no have original parametrs.
  9. #9
    Jan 2005
    us
    I realize both the posters here that English is not your first language
    But
    What machine?
    This is minimum information
    If you cannot communicate, take pictures
    Parameters are the only thing that tells the control how to run, whether it is a toaster or a color TV or a vertical mill. They are not optional, the machine cannot run at all without the correct parameters
