New Quill Drive Design - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 65
Thread: New Quill Drive Design
  1. #21
    Registered M250cnc's Avatar
    Sep 2007
    England
    Hi Mike AKA TOTALLYRC
    Valid point the issue will be flex but the outcome will be backlash.
    As i said i speak from experience
    Phil
  2. #22
    Feb 2006
    Quote Originally Posted by M250cnc View Post
    Ray i think you are going to get a lot of backlash with that design.
    The ball screw is too far away from the quill.
    The further away it is, the more backlash you will get.
    I know this from experience on my RF31
    I ended up with the ball screw very close to the quill and it is perfect but was a lot of modification to head casting so no kits available
    Phil
    Phil,
    The ballscrew is actually about as close as it it physically possible to get it to the quill on a BP without removing large parts of the head casting. And, it's closer than those on the commercial BP quill drives I've seen, including the Anilam and Elrod. The "yoke" that attaches the ballnut to the quill is made of steel, and the way it's designed, I don't think it will flex noticeably at all. Certainly there is not enough force involved to bend the 1.25" thick "yoke", and the attachment to the quill is considerably stiffer than that on another commercial drive I have, which exhibits virtually no flex. And the yoke on that one is made of aluminum.
    Well find out soon enough.....
    Regards,
    Ray L.
  3. #23
    Sep 2007
    Default Flex
    I am betting it will be just fine. I built one for a mill I have, very similar in design BUT with a cheapo Rotron ballscrew and a flat thrust ball bearing. Miine only ran .003 backlash and I am near positive all of it came from the screw and cheap bearings, none from flex of the arm going to the quill.
    Also, worthy of note is that I drove the ballscrew with a 3:1 belt drive and a nema23 stepper, 425oz. I got 80 IPM and enough force to break drill bits with ease. With the size of the servo Himmy is using his should be able to do double duty as a 20 ton press!
  4. #24
    Feb 2006
    Quote Originally Posted by Sparky_NY View Post
    Sparky,
    Yes, I think I'll have more than enough thrust, and speed. The servo is the same one I use on X/Y, with the same total reduction (10:1). X and Y will do 400IPM, and will snap off 1/2" endmills without even losing position!
    I'm not at all concerened about flex of the yoke. At 1.25", the chunk of steel is far too thick to flex, and the attachment is also very solid - it is not solely dependant on the bolt to keep it in place. Where it meets the quill it is over an inch tall, as wide as the opening in the head casting, and making full contact with the quill over that entire area. The bolt is located closer to the top than the bottom, since the highest forces will be seen when plunging. It *can't* move relative to the quill unless the steel compresses below the bolt on plunges, or above the bolt in retracts.
    The screw is a good quality 20mm 5-pitch, with zero-backlash nut. The bearings are paired angular contact, also zero backlash.
    Regards,
    Ray L.
  5. #25
    Feb 2006
    Well, this is pretty darned cool! I took the servo motor off my knee, and mounted it on the quill drive, and did some quick testing. Without adjusting the servo tuning at all (which means it's WAY off!), I can get 200 IPM without breaking a sweat. The drive is smooth and quiet. Backlash is all by non-existant - WELL below 0.0005". I'll have a short video up in a little bit.
    Regards,
    Ray L.
  6. #26
    Feb 2006
    I've never posted a video here before. Hopefully this works:
    "http://www.youtube.com/watch?v=M_AKhV9-eIk"]YouTube- P1050520.MOV
    Regards,
    Ray L.
  7. #27
    Dec 2004
    Cool Nice video.
    Hi Ray,
    Looks to me to be a well executed design with plenty of beef where needed to prevent flexing.
    To test for flex you could one step at a time run it into the table with a few indicators and see how much flex there is. I would bet that under normal machining forces the flex is minimal.
    Mike
  8. #28
    Feb 2006
    Quote Originally Posted by TOTALLYRC View Post
    Hi Ray,
    Mike
    Mike,
    I'll do some better testing once it's complete. Right now, I don't even have keys in the pulleys, and I was running most of the day with an XL pulley on the motor, and a GT2 belt. It's much happier now that I have the right motor pulley. I'm also getting about 0.0005" flex in the mounting plate, since the top of the head is not on yet - had to order longer bolts to re-attach it.
    Regards,
    Ray L.
  9. #29
    Oct 2009
    Default 2 axis
    have you considered being able to disconnect the quill drive to use the mill in 2 axis mode like a Bridgeport EZ trak?
    keith
  10. #30
    Feb 2006
    Quote Originally Posted by redford1955 View Post
    keith
    Keith,
    I thought about it, but not very hard. I didn't see an obvious way to easily disconnect it while maintaining the very solid connection necessary for good CNC performance. And I don't use the other axes in manual mode, so don't really see the need to do so for the quill either. It's just as easy, if not more so, to just operate "manually" using my pendant.
    Regards,
    Ray L.
  11. #31
    Feb 2006
    The quill drive is done, except for the belt/pulley cover the ballscrew cover, a proper stop block to limit downward travel (to take the place of the bolt and stack of washers in there now), and the limit switches. The limits will be Hall Effect switches, that will sense the steel yoke.
    Total travel is 5-5/32", which is the total travel of the quill with no drive installed. With limits set just inside this, I should still have probably 4-7/8" of usable quill travel.
    Tomorrow I'll be taking the first test cuts with it, and I expect it to work very well. I'll be testing some wicked new endmills that are, in theory, capable of slotting 1/2" wide, >0.5" deep, at over 100 IPM! I won't be able to get it going quite that fast, but I am hoping to perhaps do 1/4" deep at 50-60 IPM. If I do it, I'll post a video. Should be fun to watch!
    Regards,
    Ray L.
    Attached Thumbnails Attached Thumbnails New Quill Drive Design-p1050521-jpg
  12. #32
    Oct 2005
    us
    more videos please...
    Nate.
    Ann Arbor Meechigan
  13. #33
    Feb 2006
    Quote Originally Posted by nate View Post
    Nate,
    I will do that, next time I go out to the shop. Boy peck drilling is a WHOLE different experience at 200 IPM on the quill, as opposed to 50 IPM on the knee!
    The quill drive is working great, but I've been unable to get much real work done, due to a flaky SmoothStepper. Unfortunately, the replacement is taking a long time to get here....
    Regards,
    Ray L.
  14. #34
    Sep 2005
    Ray
    I just did a simular conversion on my quill, and I have a few questions. It seems that the quill has quite a bit of backlash on my mill, is there a way to deal with that? I am pretty sure my conversion is pretty solid, because I can not make the indicator move by tugging and pulling on the conversion parts. I can however grab where the quill handle goes and make the needle move. Your advice is greatly appreciated!!
    Walt
  15. #35
    Feb 2006
    Quote Originally Posted by wdp67 View Post
    Ray
    Walt
    Walt,
    How does your drive attach to the quill? Thats the source of the little bit of flex I have in mine, and it appears to be due to the quill itself distorting. Certainly the yoke is not flexing, and there is no backlash in any of the mechanical bits.
    Regards,
    Ray L.
  16. #36
    Sep 2005
    Ray
    I made a pretty heavy duty yoke that attaches to the quill using the original drilled and tapped hole in the quill, the yoke is cut out to fit around the ball screw and the nut screws to the yoke. I could not find a 3/8 x 24 allen head cap screw in town here so I used a bolt instead, and had to rig up a spacer because of the bolts length. I wonder if my spacer is causing all my trouble, I used a nylon spacer. Maybe I should turn a steel spacer?
    Walt
  17. #37
    Feb 2006
    Ray
    Walt
    There is no way a nylon spacer will work. You need a *steel* spacer, and it should conform to the curvature of the quill, include a boss that fits snugly into the double-D recess in the quill, and must extend as far above and below the bolt as possible.
    Regards,
    Ray L.
  18. #38
    Sep 2005
    I think I did not explain myself clearly, My yoke does fit up tightly against the quill as you stated. My spacer is on the bolt between the bolt head and the yoke. I had to use a regular bolt instead of my original idea of a cap screw. I had drilled a countersink for the head of the allen head cap screw. I did not make the countersink big enough diameter to get a socket in it to tighten the bolt so I put a nylon spacer in there to be able to get on the head with a socket. Is that more clear or am I making it worse? Reguardless, I think I need to either find a cap screw or make a spacer out of steel.
    Walt
  19. #39
    Feb 2006
    Walt
    A nylon spacer anywhere on the bolt will be roughly the equivalent of leaving the bolt loose. Under load, it will compress, allowing the yoke to move.
    Regards,
    Ray L.
  20. #40
    Sep 2005
    Thanks Ray,
    Didn't mean to hijack your thread.
    Walt
