So here are some drawings of how I've envsisioned the X-Drive on the Bridgeport. These are exploded.
I did pencil and paper for the Quill. But after making several errors I think I could have avoided, I decided to invest the time with the CAD. I think in the long run it'll be faster.
You'll see a four bolt pattern on the inner and outer plates. Thisis for a couple of bearing blocks. There will be a 5/8 in. shaft that goes through those to a coupling that will join that to the ball screw. When I replaced the ball screw I got the one to go with the existing Bridgeport power feed. I did not want to disable the ability to put the machine back into the condition it was when I got it. Again, incase the CNC craps out I want to be able to use the machine to make repairs if needed.
The drawings don't look great in the browser. You might want to download and open with something else. My Turbo CAD's save as to JPG is less than great. I'll keep working on it.
Thanks,
-jd
