bump
bump
Please can someone help I have a Bridgeport interact 412 tnc 355, the buffer batteries died and I have lost my parameters does anyone have a copy please?
Helli everyone
I desperately need the parameters for a Bridgeport VMC460/12 with TNC 2500B.
Can anybody help?
thanks for sharing Gus, I have been viewing your post and you have a lot of knowledge on these Heidenhain. I have a problem with my R2C3 TNC 145. Please message me when you can.
Is safe to use this one ? I have a Bridgeport VMC 800 with TNC 370 with no tool changer.
I replaced the batteries but still appears replace batteries, is normal ? I replaced with the 3 AA
Hi Marco , did you turn off the machine and then changed the batteries ? If you did this your parameters are gone !
the batteries were dead. i use the parameters and it worked but warning of tool change not in position because i don't have it.
Now i have another problem, relay ext. dc voltage missing.... :/
I've got the parameters working but now when I tell to the spindle start spinning the spindle just rotate some degrees to CW then some degrees to CCW and then it appear on screen Spindle Drive Fault. Can someone help ?
my milling C.N.C machine had lose ALL PARMETERS , IF possible send to me the parmeters( bridgeport vmc 500 with heidenhain tnc 370 cnc control) Tank tou ,
