Hi all,
would anyone have PLC code file for a Bridgeport 720X running Heidenhain 2500 control?
I have just installed a new control in mine, but the PLC appears to be different, so the machine is not operating as it should. I have loaded my MP machine parameters in, but I need an original PLC file?
Just to update I have now loaded a new PLC code, which appears to be working ok, except for I can no longer reference the X axis. The axis travels to the first limit switch, as it should do, then just stops instead of moving back to the reference position and loading the figure.
