Originally Posted by
meanstreakpulle
Yes, I was aware that it would have had 0 backlash from the factory, I was just stating that I would be fine with sub 0.001" of backlash. The machine is not a high production/high precision machine (as I use it) and I don't expect it to have absolutely 0 backlash. Shoot, the Hilbilly BOB/Mach 3 combination makes the machine slightly unreliable anyway, sometimes it will just freeze up for no reason and you have to power cycle to get the machine to respond again (The computer will be running fine, but no response from machine to commands).
The part that kills me about these ballscrew repair places is what they charge. I work for a large CNC manufacturer and we sell replacement ballscrew assemblies for our machines cheaper than what they want to just "reball' one and ours are high-end zero backlash ballscrews assemblies as well. I was hoping to avoid having to machine something to make one of the ballscrews I can buy from my employer work, although this would net me a new ballscrew that would then be easily obtainable for less than half the cost of just having the factory screw "reballed".
I am still on the fence, I may just reball the original screw for now. I removed the screw from the machine and there appears to be no damage to the screw it's self. I will get the collar off the end of the screw so I can remove the nut and check the internal condition of it. I have reballed older ballscrews before on machines where the control/drive system is obsolete and the screws are no longer available with good results and for very little money.
