Help! EZ TRAK SX BRIDGEPORT
Results 1 to 7 of 7
Thread: Help! EZ TRAK SX BRIDGEPORT
    Unhappy Help! EZ TRAK SX BRIDGEPORT
    Hello, mi name is Sebastián Rojas.
    i have a problem with this machine. the screen doesn´t give image and i dunno is this machine is booting up or not... it have a IDE disk drive.
    I test with other screen and same happen.
    can someone send me the operative sistem of this machine?
    and the wire details connection(service manual)?
    Today in the afternoon i gonna upload some images of the machine.
    mi eamail is: sebastian.rojas90@inacapmail.cl
    thanks in advance!
    IMAGES:
    Attached Thumbnails Attached Thumbnails Help! EZ TRAK SX BRIDGEPORT-whatsapp-image-2021-08-31-12-04-a   Help! EZ TRAK SX BRIDGEPORT-whatsapp-image-2021-08-31-12-04-a   Help! EZ TRAK SX BRIDGEPORT-whatsapp-image-2021-08-31-12-04-a
    Member Smarttowers's Avatar
    May 2020
    I recently had to construct a control box for a ez trak dx. I would suggest first thing to do is get a known good monitor and plug that in. I had to get a vga gender changer to do this but it should tell you if it's just the display which would be a good start.
    Quote Originally Posted by sebastianrojas27 View Post
    thanks in advance!
    IMAGES:
    Default Re: Help! EZ TRAK SX BRIDGEPORT
    I did that, i plug a new monitor but still without work...
    May 2020
    First thing would be to check the reset button isn't stuck in. That was the case with mine when I first got it. You can disconnect the reset from the computer board but be sure to note where it was connected. If that doesn't work you may be looking at a more serious problem.
    Before buying parts to fix it you may want to consider a conversion. I would suggest starting with one axis and check that all axis work before taking the full leap on it.
    i did it too... but same happens.
  7. #7
    May 2020
    Do you get any display when you turn the machine on?
    Even without the software it should have something come up when you put power it on.
  8. #8
    Quote Originally Posted by Smarttowers View Post
    No, there is not image. screen are in black but green led is on in screen. i think the software is corrupted. can please send me to mi email? sebastian.rojas90@inacapmail.cl
  9. #9
    May 2020
    I'm sorry I've sold the machine and mine was a dx with a drive in it so I never had the floppy software.
  10. #10
    r have a IDE disk drive and disckette option. but i need the software to reinstall it
