Need Help! TorqCut 22
Results 1 to 3 of 3
Thread: TorqCut 22
    Member slvtenn75's Avatar
    Nov 2020
    Default TorqCut 22
    HDD Failure also this morning. I do have the backup disk which i ran back in january of this year, but when i insert the 1st disk it says non system diskette microsoft backup diskette. i must have done something wrong for making the backup. Is there something i can do to make these disk work to recover my machine? Thanks for any help please!!
    Nov 2014
    Default Re: TorqCut 22
    Hey Man sucks to hear that. Did you install ms dos first? I recall using the back-up command only saves a copy of the Bridgeport operating system. but don't quote me on that.
    You know what version of DX32 your machine is running? can send you my back-up, but you'll probably need to config the parameters for your machine.
    Nov 2020
    is there a thread on here that talks about cleaning up the computer end of this machine and starting fresh? Its a checksum error that occurs when the machine is fired up. i Think maybe it needs a fresh install from a backup of the machine files and dos 6.22 idk?
TorqCut 22
TorqCut 22
TorqCut 22
