Problem Torq Cut Tool Changer Thyristor Failing
Results 1 to 3 of 3
Thread: Torq Cut Tool Changer Thyristor Failing
    Feb 2008
    Default Torq Cut Tool Changer Thyristor Failing
    First, apologies - I know there were some old threads on this subject but I can't find them anymore...
    I have a Torq Cut 22/DX32 VMC. Every few months, the thyristor (Grayhill 70M-OAC5A) which controls the "out" direction of the tool changer fails on the LC-TLAUF board. I've now replaced it three times in two years. Any ideas about the root cause of this problem so I can eliminate it?
    TIA,
    Mark
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Torq Cut Tool Changer Thyristor Failing
    ...possible failing Solenoid Coil drawing to much current (amperage) for the relay to handle. Looks like that 70M-OAC5A Relay is rated 3 amp
    https://www.digikey.com/en/products/...M-OAC5A/180934
    Member CitizenOfDreams's Avatar
    Nov 2012
    You should definitely check the coil and compare its DC resistance with a known good one. Also check if the "IN" relay gets hotter than the "OUT" relay during operation.
    Another possible reason is an intermittent short in the wiring.
