Need Help! bridgeport vmc800/22 BMDC not runnig
Results 1 to 1 of 1
Thread: bridgeport vmc800/22 BMDC not runnig
    Member mrjzuniga1980's Avatar
    Aug 2020
    Default bridgeport vmc800/22 BMDC not runnig
    Hi everyone
    i try to fix stopped machine after some years that not working, is a bridgeport VMC800 /22
    when i power up and execute run.exe the control software appear the message to said BMDC not running after this i go to startup
    the B3T.exe this is a test control of the cnc, i see some physical testing like bmdc board and other things like memory, uart and others
    but Analog test is not passing the message said, expected ADC X axis value is 0 ADC value 6, and other testing said
    ADC or DAC error!
    expected ADC X axis value is 80 ADC value 7F
    i need some help about this issue
    thank you very much
    Note: upload some images for more details of this issue
    Attached Thumbnails Attached Thumbnails bridgeport vmc800/22 BMDC not runnig-3-jpg   bridgeport vmc800/22 BMDC not runnig-2-jpg   bridgeport vmc800/22 BMDC not runnig-1-jpg   bridgeport vmc800/22 BMDC not runnig-4-jpg
    bridgeport vmc800/22 BMDC not runnig-5-jpg   bridgeport vmc800/22 BMDC not runnig-6-jpg   bridgeport vmc800/22 BMDC not runnig-7-jpg   bridgeport vmc800/22 BMDC not runnig-8-jpg
