Need Help! Bits
Results 1 to 1 of 1
Thread: Bits
    Member Heinz99910's Avatar
    Apr 2020
    Default Bits
    Good day,
    I recently build a cnc machine, i was wondering if there is anyone that will be able to give me some advice as to what type of bit to use when cutting a 3mm Aluminium Composite Panel, currently i am using a 4 flute flat end "see photos" bit, it leaves a decent cut edge however it tends to get blocked quite fast by the access material, the sizes i am using is from a 3mm to 6mm bit, i have also tried using a 6mm 2 flute flat end bit but this gives a very poor cutting edge.
    I was possibly looking at using a 1 flute end mill cutter bit, for the Aluminium Composite Panel would you recommend a flat or ball nose bit?
    Any advice will be appreciated.
    Attached Thumbnails Attached Thumbnails Bits-99850e7e-112d-4949-86bc-7a65439bf8e6-jpg   Bits-480257b7-7a05-43c5-930d-0389cc0397d8-jpg
Bits
Bits
Bits
