if this helps you can check this website this link might work https://bptparts.com/products/1104-6...26c285c2&_ss=r / https://bptparts.com/products/1104-2...26c285c2&_ss=r
Good day all.
I have recently purchased a Bridgeport EZ Trak DX Series 1 milling machine with 2 Axis control for my personal use from an Auction in UK and have it delivered to my house in Cyprus.
Unfortunately it was delivered without any manuals. The only document I have is an A4 pg mentioning only the machine Serial No (720434) and the control No (EZ 2767). Also mentioned the date of delivery Nov 96.
Anyone has the manuals PDF format that can send it over to me.
VBR
Nikos
- Problem- Bridgeport EZ Trak Series 1 Axis Motion
- Want to import DXF on EZ Trak Series 1
- Need Help!- NEED BRIDGEPORT SERIES ONE EZ TRAK WIRING DIAGRAM
- Need Help!- EZ-TRAK Series 2
- Need Help!- 1997 Bridgeport EZ-TRAK SERIES 1 DX
Here is link to manual
https://forums.autodesk.com/autodesk...March-2001.pdf
Hi
Thanks for the manual.
now is up and running.
I had to connect a keyboard in order to restart the machine.
once more Thanks.
...Congrats on new (to you) machine. also, might be a good Idea to backup control Parameters, HDD etc....asap.
DJ
Hi DJ.
I am trying to set the floppy drive in operation but is not working.
I have also installed another floppy drive but results are the same.
I have check the power from power supply and it's ok.
It might be the controller card or the grey cable.
I need to check further.
If I manage to backup parameters, can I install the program on a Pentium 4 computer and be able to write the program from desk?
If not any idea how can do it?
What program I need and in case if floppy drive is not working how can I transfer the program?
Br
Nikos
