bridgeport interact 1 mk 2 ktk drive board probs
Results 1 to 2 of 2
Thread: bridgeport interact 1 mk 2 ktk drive board probs
    *Registered User* toolmakerdarren's Avatar
    Aug 2018
    Default bridgeport interact 1 mk 2 ktk drive board probs
    hello all hope someone can help had a few problems with my interact ,its nearly there apart from a spindle problem ,when I use the m3 or m4 command the spindle wont spin ,two of the led's on the ktk sol 1 board go dim ,if I press the reset button on the ktk fac board the spindle briefly rotates then stops,ive changed a few of the obvious caps so far ,, are there any circuit diagrams available for the ktk boards pls ,any help much appreciated,
    Activation process ging's Avatar
    Oct 2018
    Default Re: bridgeport interact 1 mk 2 ktk drive board probs
    Here is the KTK Drive Maintenance manual and the Manual. I had similar issues with the spindle, ended up being a zener diode on the +-12V rails.
    https://drive.google.com/open?id=0B9...5oSlBjOWF4RXpr
    https://drive.google.com/open?id=0B9...Z3VElxcTNDbk9V
