Need help...estop activated hit (key) to clear
Results 1 to 7 of 7
Thread: Need help...estop activated hit (key) to clear
    Member Kdub424's Avatar
    Jan 2020
    Default Need help...estop activated hit (key) to clear
    Having trouble with my Bridgeport ex trak dx mill..it was working just fine had just got done milling a slot on a shaft and plunged a hole
    to start the next key way slot. Turned off mill and water to clear off all shavings and water locked mill back down in place pressed the start button and nothing..looked at cnc and said emergency stop activated hit (key) to clear...doesnt say what key to hit just says hit (key) and sometimes will come up with message saying spindle motor overload..so I've hit every key...checked my e stops..all my brake levers are loose...motor is free...all wires connected and working..oiled all oil points..checked breakers...reset breakers...e stop button not actually activated but somewhere its tripped and cant resume my very busy list of jobs
    Apr 2011
    Default Re: Need help...estop activated hit (key) to clear
    Control type (Fanuc)?
    Jan 2020
    Quote Originally Posted by drdos View Post
    Not exactly sure
    Attached Thumbnails Attached Thumbnails Need help...estop activated hit (key) to clear-15784172706747375569477563703813-jpg   Need help...estop activated hit (key) to clear-15784173476545474620048478726836-jpg
    Jan 2020
    Quote Originally Posted by Kdub424 View Post
    Not exactly sure
    this is the manual came with but says nothing about my problems
    Attached Thumbnails Attached Thumbnails Need help...estop activated hit (key) to clear-15784175473098061220240731235860-jpg
    Apr 2011
    Not Fanuc, I have no experience with this controller.
    Member machinehop5's Avatar
    Aug 2009
    Check input power.. sounds like one leg of 3 Phase is low or not working. Converter problems?
    ......you might need a wiring diagram
    https://www.cnczone.com/forums/bridg...ak-wiring.html
  7. #7
    May 2016
    United Kingdom
    Check your switches especially Z as that's where the normal problems occur
