Don't know what a Hyab is, but we simply put the forks under the base with a couple rubber pads between the forks and casting..and come in from the back (column) side. Once in the shop, it goes on some Hilman skates and moved in to position, then jacked off the skates on to the leveling pads.. Ours is a much larger version of that machine though.
