I have a problem with a Bridgeport Interact 1 MK2, when the program is running the machine is stopping few seconds until it reaches the desired position.
Do you have any idea to fix this problem?
I'm not sure whether it can be fixed by changing some parameters or is an issue with the PID servo
Do you know which parameter could be modified? (It's a TNC 2500 Heidenhain controller)
