TC22 from BT40 to CT40
Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: TC22 from BT40 to CT40
    Dec 2009
    Default TC22 from BT40 to CT40
    On the Bridgeport Torq Cut 22 machines, to switch over to CT40 tooling, is it just a matter of changing out the Carousel grippers to CT40 grippers?
    Marty
    Registered cooperjm's Avatar
    Sep 2009
    Default Re: TC22 from BT40 to CT40
    You also have to change the tool change height. You need a different pull stud for the ct40 also.
    Sent from my SM-G955U using Tapatalk
    Dec 2009
    Quote Originally Posted by cooperjm View Post
    Thanks, that part seems trivial.
    Sep 2009
    If you buy all 22 segments from EMI, they're around $25 each.
    Dec 2009
    How old is that price?
    Sep 2009
    Couple weeks ago. I bought a whole Carousel worth of segments..
  7. #7
    Dec 2009
    Thanks!
    Marty
  8. #8
    Dec 2009
    What pull studs does the TC22 use for CAT40? Is there a drawing out there somewhere or mfg. and part number?
    Marty
  9. #9
    Sep 2009
    I have some. I can send you pictures an dimensions next week.
  10. #10
    Dec 2009
    Sounds good. Thanks
    Marty
  11. #11
    Dec 2009
    Is this it?
    Also, to be sure the spindle can accomodate both, BT40 and CT40, the only difference in the change over is the pull stud and change out the grippers in the carousel?
    I just got a nice deal on a bunch of CT40 tool holders locally. I didn't have any tool holders yet. The deal was good enough for me to change out the grippers, I would have needed the pull studs anyway.
    Marty
    Attached Thumbnails Attached Thumbnails TC22 from BT40 to CT40-bpt-tc22-ct40-pull-stud-jpg
  12. #12
    Sep 2009
    No, that is not it. It looks just like the. but it has 5/8 11 threads on it. It is also shorter then the BT pull stud. I will get you a picture and dimensions when I get home this evening.
