TC22 from BT40 to CT40 - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 21 of 21
Thread: TC22 from BT40 to CT40
  1. #13
    Dec 2009
    Default Re: TC22 from BT40 to CT40
    So this one but with 5/8" threads:
    Attached Thumbnails Attached Thumbnails TC22 from BT40 to CT40-bridgeport-tc22-bt40-pull-stud-jpg
  2. #14
    Member cooperjm's Avatar
    Sep 2009
    Yes. Dimensions C will be shorter for the CT tool holder.
    Sent from my SM-G955U using Tapatalk
  3. #15
    Dec 2009
    Quote Originally Posted by cooperjm View Post
    This is the closest I found, overall length is a bit shorter as well.
    Thank you!
    Attached Thumbnails Attached Thumbnails TC22 from BT40 to CT40-bpt-tc22-ct40-pull-stud-jpg
  4. #16
    Dec 2009
    I'll wait until you get home. I sent an email to EMI as well.
    Don't want to mess this up.
    Thank you!
    Marty
  5. #17
    Dec 2009
    Here is what Aaron at EMI said about swapping from BT40 to CT40:
    "There is way more involved in that. We have had our serviceman do a swap once and between parts and labor (you need a service man very familiar with this tool changer setup) it was well over a $6000.00 event and this was in 2010. That is not a project we would recommend taking on. In fact, you can buy a used Bridgeport machining center ready for CT tooling for the cost of what it would take to change from BT to CT."
  6. #18
    Dec 2009
    Any news on the dimensions Cooperjm and the statement from EMI? I can't see why it wouldn't work other than the threads for the CT40 tool holder the dimensions are otherwise the same?
    Marty
  7. #19
    Sep 2009
    Marty
    I just spent 30 minutes looking for those to pull studs that I have. I cannot locate them at this time. I do apologize.
    If you go look up the taper length 4bt 40 compared to a cat 40 that different should be similar to the difference in the pool stud length.
    I know Aaron and Mark a EMI. I believe that they have experience with this that I do not. I do know that I put a cat 40 with a short stud and my spindle. I cannot guarantee what the drawbar pressure was though.
  8. #20
    Dec 2009
    Marty
    I'm confused. So you did do this conversion or not?
    Is the pull stud the same as the BT40 with the exception that it has the 5/8"-11 thread?
  9. #21
    Sep 2009
    Apologize for the confusion. I never said I did the conversion. I had a cat 40 tool that I used in My BT machine. I change that to out by hand. I do not have the tool anymore but I kept the pull studs in case I ever needed them again.
    I'm not sure what else you would have to change out to do the conversion. I did see a forum post that talked about doing the conversion some years ago. I know the tool change height needs to be adjusted when you switch to different tool holders.
