ANOTHER Bridgeport Mill conversion ( Build ) - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 33 of 33
Thread: ANOTHER Bridgeport Mill conversion ( Build )
  1. #25
    Jan 2007
    Default Re: ANOTHER Bridgeport Mill conversion ( Build )
    I did the motor swap to nema 40's had to make shaft adapters. Built a 70v power supply and using gecko G201x drives. My Boss 5 has 2 to 1 reduction on the lead screws. I kept the travel dials they help in calibrating mach3. Has the Kwik Switch 200 spindle tooling can be hard to get at reasonable prices. Them beasts are one stout machines.
  2. #26
    Jan 2005
    Quote Originally Posted by machinejack View Post
    Boss 5 did not come with 2:1, only 1:1, did you change them, if you did not then you have a Boss 6 which came standard with 2:1 your machine # will tell you what you have
    The travel dials are of no use if you are doing a modern retro
    Mactec54
  3. #27
    Dec 2006
    Made some serious progress on removing the old controls from the Bridgeport. i was going to strip out the cabinet and save the transformers and other electronicals, but, i feel like it will take me another half day to complete. So, off to the scrapper they go ! Now to decide if i will move the rear cabinet to the side. It will be easier to access the electronics but i will have to cut the cabinet and reweld the lower mounting bracket. I wont be able to do any serious work till next saturday so i have a week to decide..
    Attached Thumbnails Attached Thumbnails ANOTHER Bridgeport Mill conversion ( Build )-20190209_123047-jpg   ANOTHER Bridgeport Mill conversion ( Build )-20190209_141052-jpg
  4. #28
    Jan 2007
    Was told it was a boss 5 when I bought it. I made no changes to it other that replace the motors and controls. has a serial number stamped on the ways of "CNC 4208" will this tell us more about it?
    Jack
  5. #29
    Dec 2006
    Its newer than mine.. i have 1804 and 1 to 1 pulleys hey Machine Jack.. how bout some pics !!!
  6. #30
    Jan 2007
    Hay I'm at the age that I am lucky to be able to answer the telephone the first button push. I think I have an old Kodak laying around somewhere. I do have a small camera but posting the pictures may be a challenge. Will see what turns up. What cam system will you be using? I was using an old Mastercam X4 that the boss donated to me when they upgraded when I was still drawing a pay check. Recently my engineer son fixed me up with a seat from where he works and I now sport MC 2017 now that is a big relearning curve. I tried Auto Cad Fusion but found it to complicated so I'm sticking with MC. Trying to grasp solid modeling as I want to be able to machine patterns for my metal casting interest.
  7. #31
    Jan 2005
    Jack
    Boss6 was the start of 2:1 ratios, they still look like a Boss5 just a few upgrades that they had that where different mostly electrical, so could of been called any of the Boss range up until they went to servos
    Mactec54
  8. #32
    Dec 2006
    Mactec would love to see more pictures of that beautiful machine... id like to get a good one to make my computer background !!
  9. #33
    Dec 2006
    Jack will be using Fusion 360 hoping to get some help from my son's college crew
