I have just acquired a VMC800, on the rear there is the air/filter regulator which is set at 100psi, then the secondary regulator that is set at 15psi, this goes to the spindle and provides the air curtain as you would expect.
However the pipe that led from the first regulator to the top of the spindle was folded in half and cable tied and there was no air blast on tool change. After unblocking the tube the air blast works as it should but when not tool changing exhaust a continuous flow of air from the spindle.
I have disconnected the pipe from the valve and air just vents continuously out of the fitting on the valve.
Could the valve be leaking a lot of air but still do the air blast?
This is the valve... it is rated 110V AC
The other valve round the back is this one, it is not used at the moment as it powers a hydraulic multiplier that can be used for rotary tables or vices.
I swapped the valve bodies over as they seem the same except for the rated voltage but still had the same issue. Am I right in thinking that they are interchangable except for the solenoid?e they swappable?
